Pressure build up in diff
My car has developed a diff leak and I noticed when I went to check the fluid level that there was a bit of outgassing/pressure release as I removed the fill plug (case was still pretty warm, about an hour or two after I stopped driving). Anyone noticed this?
Seem like the vent might be plugged up and pushing fluid past the diff/tranny seal - anyone know if the pressure is normal (like maybe it takes 2psi to open the vent)?
Thanks.
Thanks.
There certainly is a vent on top - just wondering if it is supposed to allow some pressure build-up or whether it is supposed to directly vent to free air.
Cruise-In VII Veteran
Ben, every diff fluid swap I've done, I've noticed the 'hiss' when rem'ing the plug
www.rkt56.com
contact Rick for the best answer, he's a GM tech by trade and has built 100's of diff's
www.rkt56.com
Pretty common (expansion) to leak fluid out the vent. I change mine slightly warm & have not noticed pressure when I open, but real warm or hot could be some.
Don't know about any pressure relief metric.
Many guys just shoot it with brake clean & observe to see if it leaks again.
I fill mine till it dribbles & plug it.
I have seen some slight trace of fluid release on mine, but till it hits the ground I don't do anything but clean it off.
I was experiencing this with my C6. Talked to a local race shop (who deal almost exclusively with 'Vettes) and was told that it's a common problem ... the vent doesn't work worth a damn, and allows a pressure build-up. My car had clearly leaked fluid from one of the axle seals!
Basically, the "solution" is to pull the factory vent, tap a fitting in there, and run a short hose with a breather filter on the end so it never builds pressure ever again. I never got around to doing that though, as I went and traded up to a Z06 instead!
