It's never been necessary. You'll find people are having great success with ARP studs. Pretty much all stud failures are from someone over-torquing too often.
Understand all. I use ARP now. But the special wheel bearings I was going to get were drilled for 14mm studs vice 12mm. The person found two that werent drilled, so it is not a problem now.
