what class would my car be in?
St. Jude Donor '07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18
What group do you plan to run with? SCCA, NASA, others? Do you plan to race wheel to wheel, do time trials, or drive HPDEs? Class rules are different.
and the rules get all kinda crazy if you're talking autocross.
not really sure what all the different groups are. Just kinda growing into this. i want to run HPDE's and maybe some wheel to wheel. I love compitition and pushing it to the limit.
so if you have done NONE then you would start in the NOVICE group.
W2W - first finish the race prep of your car, gutting your car install weld in roll cage and other things based on Tech Regulations of the sanctioning body, SCCA or NASA
NASA is HP to WT ratio. that is wt with drive.
AutoCross as above
HPDE is basted on previous number of HPDEs. Not HP
AutoCross as above
AutoCross as above
Like AUNEGL said... HPDE's you start at the bottom, and work your way to the top. In Nasa for example, you would start in HPDE 1 and work your way to HPDE 4. Then if you want to progress further, you would go into Time Trials or straight into W2W.
As your car sits, it would be ST1 legal in W2W and TTU legal in TT. But, you wouldn't be competitive in either because you aren't close to the HP/WT ratio for those classes. ST1 has a 5.5/1 and yours is right at a 7.0/1. You would either need to detune to the car to run in ST2 (8.7/1) or drop weight out till you get close to the ST1 limit.
the ST1 guys have years of racing experience too.
But get her to a HPDE, NASA is a great placve to start
NASA Great Lakes has an event July 8-10, 2011 - Autobahn Country Club, Joliet, IL
http://www.nasaproracing.com/event/1175
In Nasa, it goes by peak rwhp on a dynojet. If you don't have them or your weight, you get bumped to Super Unlimited which is an anything goes class.
Check out the rules for Super Touring on Nasa's website... its a little complicated at first looking at the rules with the points and stuff, but its not too bad. But as your car sits, you are right in the middle of ST1 and ST2 as far as the weight/hp limit. I choose ST2 because I just couldn't afford to run on a ST1 budget and the competition is pretty good in ST2 with the field size getting pretty big now. We had 14 ST2 cars show up at Road Atlanta a couple weeks ago and we could have 30-40 ST2 cars for the Nationals in September at Mid-Ohio.
Did you add your weight into that ? and add 200 lbs for the roll cage too.
base wt or ideal wt is 3250 lbs, with Race prep, driver and fuel, AFTER the race.
IIRC
ST1 is 3250 lbs / 5.5 = 590 RWHP
ST2 is 3250 lbs / 8.7 =373 RWHP
( this is why the stock LS6 is so popular it fits right into ST2 )
your Car
3400 lbs / 480 HP = 7.08 so that would be ST1
need to strip 150 lbs out min
Would you say you like to run....
Flat out?
Kidding...kidding...hopefully you remember that video that went around last year.
Another good option for you if you are looking to compete is time trials. There are a ton of us that do or did it as a stepping stone to W2W racing. Same level of competition but you can still run a street legal vehicle.
To clarify the NASA wt/hp rule, it's total vehicle weight, (including driver, fluids, equipment, etc.) divided by RWHP (on a dynojet.) There are usually dynos at the track, I'd recommend using one of those since that's what you'll be checked on after a race, and we all know dyno numbers can vary 10%.
Flat out?
Im not rich and own a c5...thats the same right?
