C5 Z06 for SCCA ITE?
I know that ITE is only a regional class, however it seems pretty popular at some of the races I would run it in.
This would be mainly a enduro car...NJMP 12 hour and VIR 13 hour
I currently have LG G2 coilovers on it along with T1 sways
could I run these?
could I run these?
Depending on what motor you run, it could also be an SCCA STO.
Its the 5.7l, its pretty stock for now...I would do headers and exhaust as well as the bigger rad/oil cooler, trans & diff cooler and accusump
I use the Moroso dry sump pan they used in the old ASA stock car series on the stock car and a ARE pan on the Vette, Barnes single stage scavenge pump and a 3 gal dry sump tank. I kinda pieced it together and it was not all that expensive.
When you get near 600 flywheel hp a full dry sump is usually recommended.
If you ran it as an STO car, you could do more gutting and use lexan windshield and hatch etc. probably get it a couple hundred pounds lighter. That said, maybe pretty much anything goes in ITE. Kinda catchall class.
If you're looking for large run groups, look into your local chapters as ITE is popular in some regions and not in others. Also look at the cars they are running and times. Just because there's a lot of ITE entries doesn't mean you will be competitive, or have anyone to race with. Out here, ITE is very competitive with a lot of cars in Northern Cal, where as So Cal only gets a few cars a year and I've honestly never paid attention to competitiveness..
The fastest laps @ the VIR 13 hour where run by a 993 ITE (2:07.9) and a cts-v ITE (2:08) they both did not finish...993 killed its motor, and the cts-v killed the diff
What is the main set of rules for ITE, if you do not have a car that was built to run another series? Do you just build it to what series you want? I know you need to follow the SCCA IT saftey specs at least.
Thanks for the help
-Pete
I think in ITE, the 'E' stands for everything. I don't think it's a class with a defined set of rules. My understanding has always been that it's a 'run what ya brung' kind of catch-all class.
I would make the car legal in STO so you can run in more races than just regional, but you could also run it in ITE.
I am not looking for tons of cars every weekend, I am looking for a decent number of cars in the 2-3 enduro races I run a year.
Thanks for the help
-Pete
Thanks for the help
-Pete
1. Must use production tub
2. Must run on D.O.T. tires
All else is open. Basically Super Production for production based cars.
Being a regional only class, ITE rules can differ per region. Out here in Norther CA, we have large ITE fields and the cars are very competitive. Our "rule book" is easy:
I ran the entire life of the car, until its recent demise, with a stock fuel tank.
T1 and STO are national classes
ITE is a regional catchall as stated above.
I would build to T1 or STO then you have options to run either of those plus ITE. In Socal there are not many STO cars and sometimes we double dip into STO with our T1 cars. We would not be competative with real STO cars but since there are not many around here we play there. So if you build to T1 you can run T1, STO, ITE. Being nationally licensed give you options to run more races at more varying times.
I have all but given up on trying to run SCCA ARRC at Road Atlanta this fall. ITE (ITO in the SE) board didn't seem real crazy about a PTA/C5Z running without a crap load of ballast, and there are tech restrictions (need bars forward of the A pillar verticals, these are additonal mod pts for NASA PT rules). And wasn't it STO (which would be a joke of a class for us) that requires fuel cells? The closest thing to us (lap time) really is T1, but bushings, small clutch, and lack of a dash will keep us out of that. IMHO it's pretty stupid your car would be illegal for T1 with a bushing change but you can run $8k shocks Headers are ok but a small clutch is not (heck we still got cats, lol)
Bottom line, NASA - SCCA is a one way street. I bet we could get 4-6 NASA PT C5Z06's in the ARRC in Nov if we could find a home.
Bottom line, NASA - SCCA is a one way street. I bet we could get 4-6 NASA PT C5Z06's in the ARRC in Nov if we could find a home.[/QUOTE]
In the SE it is called ITO. Same as ITE
Put your dash back in and run T1.
