AP T1 questions
AP T1 questions
To you guys who have the brakes, a few questions after the install;
Why are two different caliper to bracket bolts supplied? I used the short bolt with two shims. The long bolt seemed too long.
Here is a pic of the caliper to bracket connection
As far as the pad fitment, they stick out from the rotors about 1/2 mm, is this ok?
The longer bolts were the ones Gary originally sent with the kit, requiring 2 sets of Nordlocks. He then sent out the shoulder bolts with the shortened threads that only require 1 set of Nordlocks. Brake package looks nice!
@Len, thanks for the kit. It turned out very nice.
@Derek, those rotors are the same size as the c5 rotors.
I guess I will take out one of the Nordlocks as I used two on the short bolt. I also had to put a shim between the caliper mounting bracket and the spindle. Without the shim, you could not turn the wheel with the lugs torqued, the inside pad did not have enough clearance.
I don't think those are Gary's hats (and I know that's not a J-hook AP ring). what rotors are you running? (they look like coleman rings).
The AP j-hook's may have a slightly larger OD. (ie, that bracket is built to mount that caliper on the 12.8" J-hook AP ring, if you are using a different "12.8" ring, it may have a slightly smaller OD)
Those are performance afx rotors.
I believe these are ones for c5 brakes. On their site there is another sold rotor for AP.
http://shop.performanceafx.com/C5-C6...s-C5RTRSTF.htm
I would rather have the J hooks but I hope these can do the trick?
Do you guys see a problem with that small pad overlap on the rotor?
Tim
Tim
http://www.nord-lock.com/default.asp?url=43.16.37
Regarding your 2nd question about the pad fitment - mine do that also and some of the pictures I've seen of others suggest its normal. Hasn't been a problem, as the pads wear down the little "lip" just breaks off.
I think they will be fine-but I am shade tree, so what do I know?
The Nordlocks should be used in pairs. Teeth face each other.
Not sure why you have two different length bolts. Mine had the ends of the threads ground on a 45 degree angle to clear the upright ears (an assumption here) I still had to file the outside flashing on the upright to clear the ends of the bolts.
I think you can see why the threads need to be chamfered:
I use stock rotors and DTC-70 pads which match exactly at the OD. I would not worry about a little bit of overhang.
My brackets were gold anodized.
I also had to shim the bracket .040" to center the caliper on the rotor.
Tim
