Stoptech or Brembro Users - consumables question
For those of you running these BBKs on track duty what are the replacement costs - Rotor rings and pads. How much longer do the consumables last as compared to stock.
Thanks!
Thanks!
I run Stoptech's and I have found the consumables last 2 to 3 times as long. I have run both Stoptech's and Brembo's. Brembo consumables are 60 to 80% higher in cost than the Stoptech's. Don't get me wrong they are both much better than stock. But the Brembo's have a much higher operating cost and last about the same as the Stoptech's. Just my opinion! One thing nice about the Stoptech's is you can run 14" rotors front and rear. JD
If I were currently in the market for a BBK, I would give this a close look as well.
http://forums.corvetteforum.com/auto...brake-kit.html
I run Brembo's and compared to a stock system the pads are less expensive and last four times as long. Rotors and rings are expensive but have yet to replace or crack one in two years. As far as performance I feel there is no comparison, I tried many different pads and rotors on the stock system and could never get satisfaction. I would go with this setup again without question, when you can run in the corner as fast and as deep as a Porsche you appreciate how good they are
Rotor with hardware for Stoptech's $220.00 EA, Brembo's with hardware $375.00Ea. Front Race pads for Stoptech,s about $300 to $400.00 Brembo's $500.00 plus the pads vary alot depending on who's and what material. The pads for the Stoptech's are used on many applications and therefore competitively priced. I have not run Brembo's for several years so this is my experience from the past with Brembo's. I'm getting about the same performance with the Stoptech's as with the Brembo's and about the same life out of the consumables. JD
Supporting Vendor
I'll throw another vote in to check out the Hardbar/Essex/AP Racing T1 brake package. Spare AP Racing J Hook discs are $249 each, and race pads are in the $150-$210 range. The metallurgy on the discs is the same as what C6R's are running in ALMS, and the pads are 20mm thick. Both the pads and discs last a very long time...many times longer than stock. Check out some of the other owner feedback on this forum.
I looked at this kit and spoke with gary about it. It is an impressive kit - no doubt but i just cannot get by the fact of going to a smaller rotor for my C6Z. I understand it will perform and bigger is not better but why go smaller? i cannot get by this.
i would love to hear other guys experiences with this
http://hardbarusa.com/hardbar/produc...roducts_id=179
As stated I run the Brembo BBk kit but must clarify that I use a racing rotor ring and not the one for street kit, calliper is the same. With Hawk pads the car stops great on the track. the racing rotors are more expensive and are 14 inch but i have yet to crack one in two years.
I have purchase a spare set of rotors, hats, hardware and pads for my setup, cost was around $2500
