Too much tire?
Too much tire?
What factors set having too much tire width or too large an difference between front and rear widths for a road course car?
Wider cant always be better!
What indicators does the driver have when tracking the car to help optimize the tire selection?
Just a humble opinion here, but I thought that width was limited by availability, cost, and more importantly, what can reasonably be engineered to work with the vehicle and have it run reliably. I would think you go wider until you have a neutral handling car assuming that is your preferred driving style (for most I think it is).
ultimate grip is not deteremined by width, contact patches just don't go up very much. Plus some of the fastest cars on track now are TTA guys, running 275 or even 255mm tires.
I think wider tires hold up better, manage heat better etc. So a car with higher power/torque needs a larger rear tire to manage the extra heat generate by acceleration, not cornering.
Therefor I feel you can go just as fast on a 275 as you can on a 335, just for a shorter period of time. Also, in a Vette, running a tire 20mm wider or so helps keep the rear from losing grip prematurely as it heats.
Just my opinion, I was forced to run wider tires on the front recently (my wide tires were shorter than the narrow ones) and the car was perfectly balanced.
It also depends on the rim you are using. If you have a set rim width, going too wide causes tire mechanics problems, basically because the sidewalls are angled too much. You can end up pulling the shoulders of the tire off the road surface and not properly loading the sidewalls of the tire.
I seem to remember seeing an article in Racecar Engineering (or maybe Sports Car) that did a test on the opposite example. For a given tire size, nearly all tires will have more grip and better response with a wider rim. Obviously this has a point of extremes too but it was an interesting read.
Pro Mechanic
My past experience is going to have me voting for the largest balanced tire & wheel package you can fit. My C4 is 335 18s all the way around. My C5 315/18 front 345/18 rear. Each step bigger on both cars required adjusting suspension. Each step larger = faster lap times. Sure if you put these sizes on a Miata or F500 it would go slower. With less power & weight.
Same here. My car always got better with more rubber(currently running a 305 square setup). As for the contact patch, I have got to dig up a technical article by Michelin; even though the contact patch on a 275 is the same as a 335, its the shape of the larger contact patch that yields the grip advantage when cornering.
Same here. My car always got better with more rubber. As for the contact patch, I have got to dig up a technical article by Michelin; even though the contact patch on a 275 is the same as a 335, its the shape of the larger contact patch that yields the grip advantage when cornering.
I assume both of you are referring to autocross, not road race/HPDE?
I am hoping to see more responses that consider the impact on the handling characteristics of the car.
Things like:
Effect of wider rears on corner exits.
Interaction with anti-sway bars,
Things like:
Wider can't always be better!
performance is discussed in
The Racing & High Performance Tire
By Paul Haney
Published By: SAE International and TV Motorsports
Published: March 2003
Pages: 286
13 Chapters
Binding: Hardbound
Product Code: R-351
Product Status: Available
ISBN-10: 0768012414
ISBN-13: 978-0768012415
Table of Contents
From SAE
From Amazon
Regarding tire width, a brief exerpt of what Mr Haney has to say:By Paul Haney
Pages: 286
13 Chapters
Binding: Hardbound
Product Code: R-351
ISBN-10: 0768012414
Table of Contents
From SAE
From Amazon
Why Wider Tires Are Better
"For the same vertical load and internal pressure, a tire with a
wider tread has a shorter, wider contact patch than a narrower
tire ...
A shorter contact patch at the same slip angle begins to slip at
roughly the same distance from the leading edge as with a longer
contact patch. But the shorter contact patch has more of its
length stuck to the road than the longer, narrower contact patch;
and therefore a larger overall portion of its overall area is gripping."
tire ...
I agree. If you over tire a car it will slow due to mass.... There is a happy balance. Per Froggy.... If you are not validating with a pyrometer, you may put to much tire and not be able to get them up to temp./using them efficiently.
Large rears are used some times for the durability of the casing, especially in pure race tires like the ones on Newlanders car. The larger the air chamber the more load the tire can typiclly handle.
Our GTA type stock cars run some terrific lap times using a 10" wide tire on car that make about 500 FWHP. The 27x10x15 Hoosier 3035
gives these car incredible side bite and then the less mass and rolling resistance makes for a very fast straight line tire. I think that GT-1 type tires on these cars would be overkill. Might be a bit faster across the apex and under braking, but slow you down on acceleration. Plus they will put a much bigger hole in your wallet. 1600 a set vs 600 a set.
When we get these cars up around 600 HP (SPO types) they get a lot more difficult to drive and you really have to roll smoothly into the gas off the corner.
Location: Boston, Dallas, Detroit, SoCal, back to Boston MA
the issue is getting heat into the tires
Corvette are relatively heavy cars.
a A-mod can run whatever size they want.
They don't run 335's because they can't get the heat into them.
It's interesting to see that the LMP cars are going with bigger fronts now to match the rears. This all started with the Acura/HPD car but I know that Audi and Puegot have done that as well now. I seem to recall that when HPD first did this they had issues finding a power steering system that could deal with that big a tire.
I guess that is a long winded way of saying that it sure seems like bigger is better within constraints of the rules.
