I have not balanced by tires/wheels for a couple of years due to all the rubber that is picked up and the fact that the tires spin on the wheels and have not had any issues nor felt it.
Not sure about the rotors though
I balanced a Coleman rotor/cast iron hub years ago. It took a 1/4 ounce at a 2" radius. I removed an integral solid rotor from the hub and machined it to accept Coleman rings. It probably made no difference as the track pick-up on the OD of the tire was at a 13" radius.
