DeltaWing at Le Mans 2012
Old 07-31-2011, 08:49 AM
Corvee
Corvee's Avatar
Default DeltaWing at Le Mans 2012
ACO approved Highcroft Racing entry at Le Mans in 2012 as "unclassified entry". The car may be at Sebring as well. 1000 lbs and 300 hp! Article in Road & Track:
http://www.roadandtrack.com/racing/m...ult-on-le-mans
Old 07-31-2011, 09:54 AM
Rob31
Rob31's Avatar
Thats not a car, its a lawndart with wheels .What are these guys on ?
Old 07-31-2011, 12:02 PM
AU N EGL
AU N EGL's Avatar
WOW shades of the 40 year old Turbine indy cars
Old 07-31-2011, 02:35 PM
Zoxxo
Zoxxo's Avatar
It's a very cool car and a very cool concept. Read the article and see who's behind it.
Z//
Old 07-31-2011, 02:49 PM
CHJ In Virginia
CHJ In Virginia's Avatar
I would think that the extremely narrow front track would create major cornering problems. That design might be great for a drag strip or Bonneville, but I just can't see how it would work on a road course.
Old 07-31-2011, 04:32 PM
BFoster
BFoster's Avatar
looks terrible i really hope it fails miserably and all the hype goes away!
Old 07-31-2011, 04:45 PM
Rob31
Rob31's Avatar
QUOTE=AU N EGL;1578280523]WOW shades of the 40 year old Turbine indy cars[/QUOTE]
I just saw a Turbine car # 66 driven by Bruce Mclaren at a block party/car show in Barrington Il 20 minutes ago.
Those guys were brave . two inches separated the drive from the rt .side of the car turbine & all wheel drive cool
New Indy concept ....
Old 07-31-2011, 07:35 PM
Zoxxo
Zoxxo's Avatar
For sure. We wouldn't want anything new and different to be successful.
Z//
Old 07-31-2011, 08:11 PM
Corvee
Corvee's Avatar
"New ideas are not only the enemies of old ones; they also appear often in an extremely unacceptable form."
— Carl Gustav Jung
"Don’t worry about people stealing your ideas. If your ideas are any good, you’ll have to ram them down people’s throats."
— Howard Aiken
Old 07-31-2011, 09:52 PM
mgarfias
mgarfias's Avatar
Its hideous. That said, I'll be interested to see what it does.
Old 08-01-2011, 12:49 AM
RX-Ben
RX-Ben's Avatar
I'm all for it. People always complain about the lack of innovation, and then something like this comes out and it get poo-poo'd.
Old 08-01-2011, 09:46 AM
BrianCunningham
BrianCunningham's Avatar
Location: Boston, Dallas, Detroit, SoCal, back to Boston MA
Like to see the math on the cornering numbers
Old 08-01-2011, 09:51 AM
Scooter70
Scooter70's Avatar
Me too. The article says that the front tires are only 4" wide. How the hell does this thing turn with 4" wide tires and such a narrow front track?
Old 08-01-2011, 10:53 AM
Zoxxo
Zoxxo's Avatar
No doubt that's everyone's first question.
The car is designed to weigh less than 1000 pounds (!) That's 600+ pounds less than an F1 car. That will certainly help a lot
I expect that the calculations have been done (many, many times) to show that it can work or they wouldn't be putting so much time and energy and money into the effort. It will be interesting to see how it turns out.
Z//
Old 08-01-2011, 11:39 AM
BrianCunningham
Most of the weight is in the back
so you calculate the weight per contact patch area.
Old 08-01-2011, 12:01 PM
bags142
bags142's Avatar
I wonder if it will slow one of the rear wheels to assist in turning?
Cause I can't understand how it will turn otherwise. But, I also only have a degree in total BS, so what do I know
Old 08-01-2011, 01:49 PM
Rob Willis
Rob Willis's Avatar
I'm with YOU! ...and I'm a huge ALMS and even Highcroft fan, but this thing is horrible.
To DeltaWing at Le Mans 2012
Old 08-01-2011, 02:20 PM
joemoia
joemoia's Avatar
Computer simulation of the DW at Le Mans
http://www.racer.com/video-le-mans-d...rticle/204862/
Old 08-01-2011, 02:23 PM
shakedown067
shakedown067's Avatar
St. Jude Donor '12-'13
I dig it, and if there is very little weight up front, which it looks like, you shouldn't need too wide of a track or wheel. I hope it makes it out to Sebring as I'd like to see it in action. If it survives there, it should do good at LeMans.
Old 08-01-2011, 02:38 PM
mAydAy121
mAydAy121's Avatar
St. Jude Donor '10
The physics (and I'm sure I could do the math to support my claim) of it says its not likely to run very well. While it is possible to make a car corner on those small tires by playing with weight distribution, you can't overcome weight transfer to the front under braking....
Quick Reply: DeltaWing at Le Mans 2012
