FS- Continental GrandAM GT-0 325/680-18 Slicks
Old 08-05-2011, 10:35 PM
Sidney004
Sidney004's Avatar
Default FS- Continental GrandAM GT-0 325/680-18 Slicks $60 each
I have got (4) Continental(built by Hoosier)325/680-18's slicks. They are off a front running Camaro and in really good shape with only 2 sessions. They are too big for me. They are really fresh, four weeks old from the Laguna Seca GrandAm race. Here are the specs: the O.D. is 26.76", by comparison a 315/30-18 is 25.45", a 315/35-18 is 26.68,a 335/30-18 is 25.9", a 345/35-18 is 27.50" . The slicks are a brand new construction and are different than the R6/A6 or R80/R100 series. Continental(Hoosier) told me that they designed the GT-01's to be multi purpose for the GT spec GrandAm cars, there is only one compound and one construction for the entire year for the series, including the 24 hours of Daytona, they were designed to withstand the heat(they run at 220F+ at Daytona) and loading of Daytona at the expense of speed at the other tracks. They fit a 12" wide rim. The rubber is definitely harder than than the A6. 28-30 psi hot, if you have the proper camber(3+.)
Once they are warmed up, they should provide some fantastic grip at the rear, the pros at Laguna Seca were really able to put the power down early using these tires but you probably need to be careful for the first lap. I am asking $125+ shipping for a set of 2, but if someone wants to buy all 4, we can make a deal. The cheapest shipping I have found is Greyhound freight, you need to pick it up at the bus station. http://www.continentalrace.com/downl...IONAL-DATA.pdf
Feel free to call me directly at (925)354-1571 if you have questions or want to deal.
Old 08-07-2011, 10:29 PM
Sidney004
Sidney004's Avatar
Price dropped.
Old 08-12-2011, 08:01 PM
Sidney004
Sidney004's Avatar
Price dropped. I need these out of here. No one needs some rear slicks?
To FS- Continental GrandAM GT-0 325/680-18 Slicks
Quick Reply: FS- Continental GrandAM GT-0 325/680-18 Slicks
