32 mm Addco Front Sway Bar - Wall Thickness?
Old 08-17-2011, 03:05 PM
acrace
acrace's Avatar
Default 32 mm Addco Front Sway Bar - Wall Thickness?
Two questions - I have one of these for a C5.
1) Anyone know the wall thickness?
2) I assume that this also swaps onto a C6 Z06?
TIA
Old 08-17-2011, 04:00 PM
TedDBere
TedDBere's Avatar
TIA
I think they made two of them, one solid and one hollow. Not sure of the hollow thickness or whether or not they'll work on a C6.
Old 08-17-2011, 04:27 PM
acrace
acrace's Avatar
The one on my C5 Z06 is a hollow one. The Addco catalog lists the application(s) as being for '97 to '10, but was hoping to have someone verify. I guess that I'll just pull a wheel off my C5 Z06 and measure the thickness where the end links go through (they crimp the wall down at the ends of the bar).
Old 08-17-2011, 08:48 PM
acrace
acrace's Avatar
Would 6 mm wall sound correct, anyone?
Old 08-18-2011, 04:30 PM
Van Steel
Premium Supporting Vendor
Van Steel's Avatar
2) Yes
Old 08-19-2011, 09:27 AM
acrace
acrace's Avatar
Originally Posted by Van Steel
1) .250
2) Yes
Thanks for the info and swapped the bar onto the car last night.
To 32 mm Addco Front Sway Bar - Wall Thickness?
Quick Reply: 32 mm Addco Front Sway Bar - Wall Thickness?
