Having an accusump is nice
Old 08-17-2011, 07:40 PM
BrianCunningham
BrianCunningham's Avatar
Location: Boston, Dallas, Detroit, SoCal, back to Boston MA
Default Having an accusump is nice
Nothing like having oil pressure, BEFORE you start the engine!
Old 08-17-2011, 08:20 PM
doveboat
doveboat's Avatar
Sure rub it in ......
Ed
Old 08-17-2011, 10:20 PM
msracing
msracing's Avatar
Default accusump
I am thinking about installing one on my C6 that i track a lot..
i fabricated my own oil cooling system with 2 -19 row oil coolers and they have worked very well ... so now i thinking i want to install a accusump ..
i have been reading about oil pressure problems when using sticky tires and specially when you are in a hard left hander.. what size accusump did youo use. 3 qt? and how did you plumbed it ? any info would helpp
Thanks in advance...
Manny
Old 08-17-2011, 10:30 PM
BrianCunningham
I need to lookup the part #
It's out back with the oil cooler, which has it's own fan, and an oversized filter.
Here's an earlier pic
I like Paul over @ theBowTieShop.com take care of install, SloRvette is his handle here.
Old 08-17-2011, 10:34 PM
fallen
fallen's Avatar
Location: Upper West Side, NY Very Downtown Houston, TX
Cool. I have one also.
What is the max pressure you are seeing while the sump bleeds out, but before starting the motor? Just curious.
My varies depending on whether the motor is hot or cold. Most likely due to increased clearances when hot.
Cold the most I have seen is 21.
Old 08-17-2011, 11:06 PM
BrianCunningham
Haven't had it to the track yet.
Still breaking in the clutch.
I start the engine when it hits 40psi.
I want to make sure it still has some in it when I fire it.
Old 08-17-2011, 11:31 PM
waddisme
Support Corvetteforum!
waddisme's Avatar
My 3 qt gets to about 30 before I start it. I flip the switch before I start and then turn it back off after motor has fired. Works pretty nice. Nice to know you have backup at the track.
To Having an accusump is nice
Quick Reply: Having an accusump is nice
