Track water pump for C5Z
Gotta feeling the water pump is leaking after 25K track miles. Any suggestions on a replacement pump? my only requirement is that the pulley is in the same location as the current one and is the same size.
I have seen some discussion of using the LS3 pump. Does this require a different belt?
I have a Davis track radiator and no other cooling issues than a leak.
