Best priced "D" shaped steering wheel...
Old 08-28-2011, 10:40 AM
VGLNTE1
VGLNTE1's Avatar
St. Jude Donor '14-'15
Default Best priced "D" shaped steering wheel...
I am so sick of the school bus sized steering wheel. I also dont want to pay and arm and a leg for just a wheel either. Whats the best options? And also, how in the world do you install it
Old 08-28-2011, 11:54 AM
sperkins
sperkins's Avatar
The most popular options are 330mm and 350mm. I bought a 330mm Sparco and immediately sold it because it was way too small for me. I finally landed on a 350mm Momo and it's perfect.
The least expensive option that I know of for installation is to buy the Grant quick release and adapter hub from Summit racing. I'll post the links later.
Old 08-28-2011, 02:49 PM
RX-Ben
RX-Ben's Avatar
I have a Momo Mod 88 in 320mm. I like the small size and this one has a horn button.
If you don't want a quick release, just get a momo hub. Removal of the old wheel can be trying, to say the least (Matco puller arms will break).
You'll need to add a resistor to keep your airbag light off, do a search for that.
The wheel is one of the best upgrades I've done.
Old 08-28-2011, 06:22 PM
USAsOnlyWay
USAsOnlyWay's Avatar
That adapter is slick. Do you know if it allows or deletes horn functionality?
Old 08-29-2011, 02:01 PM
dc5-s
dc5-s's Avatar
how do you wire the horn button?
Old 08-29-2011, 02:24 PM
yakisoba
yakisoba's Avatar
I've got an OMP wheel, and love it. Not d-shaped, just a bit smaller than stock.
Old 08-29-2011, 02:31 PM
RX-Ben
RX-Ben's Avatar
you cut the red horn button wire and connect it to the horn setup that comes integrated on the Momo wheel. Pretty easy.
Old 08-29-2011, 10:34 PM
mphox
mphox's Avatar
I have the same setup but also have a quick release hub and the momo hub adapter from this website
http://ltbautosports.com/dilquicrelhu.html
Wheel is a little closer by about 1.5" but I like it better
Don't worry it is no where near as close as the circle track guys like it.
Mod 88 comes in 320mm and 350mm also on website above
Agree removal was the hardest part
Old 08-30-2011, 04:38 PM
USAsOnlyWay
Got pics?
Does the horn button ring stick out a lot? Hard to tell from pics.
Old 08-31-2011, 02:38 PM
PA Z06
PA Z06's Avatar
Heres a pretty good thread from the past that should be helpful
http://forums.corvetteforum.com/auto...ng-wheels.html
To Best priced "D" shaped steering wheel...
Quick Reply: Best priced "D" shaped steering wheel...
