Cuts in Hoosier Tires
Old 08-30-2011, 04:51 PM
USA1C5
Support Corvetteforum!
USA1C5's Avatar
Default Cuts in Hoosier Tires
After inspecting my set of Hoosiers, I noticed some cuts in all four tires. I think the cuts are minor but I think about that, particularly at 150+. At what point is a cut in the tires too much. I have been told that cuts are normal for these soft tires. What do you guys think? At what point would you replace them? If I replaced the tires when ever I got a cut, I would be replacing them after one use is some cases. Input please.
Old 08-30-2011, 05:21 PM
VTME13
VTME13's Avatar
Are they cuts or what look like little tiny slices left over from rocks pulling out of a cold tire?
Old 08-30-2011, 05:37 PM
USA1C5
USA1C5's Avatar
I'm not sure how they got there. I assume they are from sliding the tires over rocks on the track. None are over 1/2" long, most are about 3/8" long or less and depth maybe 1/4" at most probably less (they still hold air). Maybe a couple cuts or so on each tire. I just don't want a tire to blow out or come apart on me. If a slow leak developed I could live with that but not a blow out.
Old 08-30-2011, 05:47 PM
JDIllon
JDIllon's Avatar
Pictures please, hard to help without knowing what they look like? JD
Old 08-30-2011, 05:48 PM
VTME13
VTME13's Avatar
Without seeing it in person, it's hard to give a solid opinion. However, last time I was at Summit, the rocks in the paddock did the some thing similar to my A6's. After the next time out on track, I checked them before hitting the gravel in the paddock and all the cuts/ rock wounds "healed"...
Old 08-30-2011, 05:56 PM
USA1C5
USA1C5's Avatar
Mine actually look like cuts. Like they were done with a knife, but not deep enough to lose air. Mine are R6's for what ever that's worth.
Old 08-30-2011, 05:57 PM
USA1C5
USA1C5's Avatar
I'll try to takes some pics tonight.
Old 08-30-2011, 06:53 PM
USA1C5
USA1C5's Avatar
Here is a sample of some of the cuts. Quality of the pics not the best but best I could do.
Old 08-30-2011, 07:44 PM
VTME13
VTME13's Avatar
Yep, that's similar to what I saw after brushing off gravel.
Obviously, if you're not comfortable with it, don't run it.
Old 08-30-2011, 07:58 PM
USA1C5
USA1C5's Avatar
I would be comfortable running these if others do with no problems. This is my first set of Hoosiers. Maybe this is normal, I don't know. I've run street tires up to these Hoosiers. Has anyone had problems running Hoosiers with cuts like this? I would not be comfortable running these if anyone has had a problem with cuts like this.
Old 08-30-2011, 08:36 PM
froggy47
froggy47's Avatar
I would run them if they were mine, we report you decide.
Old 08-30-2011, 08:46 PM
USA1C5
USA1C5's Avatar
Thanks for the input, I feel better about them already. I was hoping for some positive input.
Old 08-30-2011, 09:19 PM
JDIllon
JDIllon's Avatar
I would run them! Now that you have signed the hold harmless agreement, I can give you my opinion!!! LOL! JD
Old 08-30-2011, 09:26 PM
BuckeyeZ06
BuckeyeZ06's Avatar
That's normal.
Old 08-30-2011, 09:27 PM
USA1C5
USA1C5's Avatar
Thanks for another positive input.
Old 08-30-2011, 09:28 PM
USA1C5
USA1C5's Avatar
Originally Posted by BuckeyeZ06
That's normal.
Old 08-30-2011, 09:32 PM
NASCAR314
NASCAR314's Avatar
another, "Looks Normal to me" here.
They do have steel belts between polyester belts, so a cut would have a hard time getting thru.
To Cuts in Hoosier Tires
Old 08-30-2011, 09:51 PM
USA1C5
USA1C5's Avatar
and another
Old 08-30-2011, 10:05 PM
jlutherva
jlutherva's Avatar
Howard,
I'm willing to test them for you!
Jim
Old 08-30-2011, 10:14 PM
USA1C5
USA1C5's Avatar
Originally Posted by jlutherva
Howard,
Jim
Thanks Jim. I got a new set of Hoosiers but I was just trying to use all the rubber up on these first. How's things going?
Quick Reply: Cuts in Hoosier Tires
