Aluminum seats without a cage?
1 Post
St. Jude Donor '11-'12
I've been looking at seat options, but while searching on google some say no to having aluminum seats without a cage. but this was in a drag racing section....
does this also apply to road racing? Im looking at some cheap options for seats.
Guys do run them!! But I called Kirkey and they say not to run there seats unless the seat is supported in the back to a cage or some sort of support! They told me that the seat is not designed to be run unsupported. And that it could collapse the back. They said the aluminum is not like the fiberglass because it does not flex, after so much stress it just breaks. I would contact the seat Mfg and see what they say before installing. JD
Received 8,928 Likes
You choose the size of an aluminum seat by sitting on a bench and having somebody measure the distance across your butt and then going with the size that will fit that measurement. Waist size doesn't matter. You will be snug. The race seat will hold you in a lot better than a Sparco will since the sides along your legs are higher, the sides along your waist are deeper and the shoulder supports are probably a little better as well. Run a brace from the seat to the harness bar. Remember you have to get two of them since most organizations require equal restraints for the passenger/instructor. To outfit the car you will need to spend about $350/seat, $350/seat mount, $100/seat back brace plus some customization work. If you don't like the way the seat fits or you need more room some place all you do is bend it or cut it. Can't do that with a fiberglass seat. By the way braces are recommended for fiberglass seats as well. Even though supposedly FIA certified they don't seem to hold up that much better than aluminum when in a crash. First your body gets thrown forward against the belts and then it rebounds back into the seat and that is when the seat back is broken unless it is braced. You can also order the aluminum seats in either 10 or 20 degree laybacks. I have one of each in my car. Driver's side is 20 and the passenger side is 10. The 10 is laid back more in the mount thus the seat bottom comes up and catches the legs and butt at a sharper angle than my seat does. This helps hold the multi size passengers that I get in place when they are in the seat.
Bill
Bill
Find a flat bench or an old footlocker. Grab two shoeboxes. Sit on the bench and slide one shoebox against each hip. Hold the shoeboxes in place and stand up. Now use a tape measure to get the distance between the two boxes.
That number will be your basic seat size....15 inches, 16 inches, etc.
You can go all fancy and get a bunch of other measurements for a completely custom seat, but that will cost you a lot more. A basic aluminum seat in your correct size can have all the other stuff (shoulders, knees, etc) adjusted by bending the aluminum to fit.
Matt
Are the seat braces mounted a little high here? We mounted mine on the Kirkey seat at a lower position on the seat back. It appears yours are at neck level. I am inquiring here as to whether it matters at what level they are mounted. Thanks
also right behind the Hans device.
If I went under the harness bar that would put it right between the harness holes.
Mentioned I am looking at containment seat now.
I think you could put a brace to the bulkhead behind the seat. It is as thick as the seat material. I could see riveting a brace there and you'd likely be just fine.
Bill
Bill
