Castrol SRF - Two Different Containers - Same Stuff???
Old 09-01-2011, 07:17 PM
rikhek
rikhek's Avatar
Default Castrol SRF - Two Different Containers - Same Stuff???
I'm used to buying SRF in this bottle/packaging:
http://astore.amazon.com/cheapamazon...ail/B0018EWAWI
It's also available in this packaging:
http://www.powersportparts.net/Produ...ctCode=83-0345
Anybody know if it's the same product? Why the difference? The Castrol site shows it in the bottle/packaging provided in the first link above.
TIA
Rick
Old 09-01-2011, 07:33 PM
redvetracr
redvetracr's Avatar
same stuff, metal can is old packaging, plastic bottle is newer, whether it matters is up to you.
Old 09-01-2011, 07:36 PM
rikhek
rikhek's Avatar
Thanks for taking the time to respond. Is there a shelf life? I wouldn't think so as long as it has an air tight seal?
Rick
Old 09-02-2011, 12:47 AM
bluemagoo
bluemagoo's Avatar
I've never used Castrol SRF from a metal can but I know the plastic bottle has changed recently. It's the same stuff as far as I know (I do remember when brake fluid used to come in metal cans though). I actually like the old-style plastic bottle better - it's easier to grip when pouring. I contacted Castrol a while back about the shelf life question. Their reply follows:
Thank you for contacting Castrol.
There is no shelf life for Castrol SRF, however we would suggest that for maximum protection and performance, the product be used within 2 years of the date of manufacture. Regardless of the storage conditions, moisture can get into the product via osmosis through the plastic. No partially filled bottles should ever be used once open, use or discard.
Thank you again for your interest in Castrol, The Technology Leader !
Old 09-02-2011, 01:02 AM
bluemagoo
bluemagoo's Avatar
I used to buy it in this bottle:
Now it comes packaged in this bottle:
Old 09-02-2011, 02:17 PM
StKnoWhere
StKnoWhere's Avatar
A metal can will have a longer shelf life due to being more effective blocking moisture absorption in the fluid.
There is a moisture barrier layer in the plastic bottle but it will not be as good as the can.
Moisture absorption is why they recommend not using fluid from a bottle that has been opened and set around a while.
In real life, probably not much difference for new stock.
Old 10-04-2011, 06:16 PM
rustyguns
rustyguns's Avatar
I got confused by the new container also !
I just love this stuff..hate the price but it lasts the whole season. so cost is actually less plus.... less flushing
FYI this stuff works damn good after opening it and sitting on the shelf for a year! Fricken amazing!!!
... prob gives you cancer so don't drink it!
Old 10-04-2011, 08:18 PM
John Shiels
John Shiels's Avatar
Location: Buy USA products! Check the label! Employ Americans
Cheaper and way safer per mile.
Old 10-04-2011, 08:20 PM
rustyguns
rustyguns's Avatar
AND WET BOILING POINT OF 518 DEGREES
THAT'S W E T !!!!!!!!!!!!!!!!!!!!!! WOW!
To Castrol SRF - Two Different Containers - Same Stuff???
Quick Reply: Castrol SRF - Two Different Containers - Same Stuff???
