Pfadt bars & pillow blocks installed
Old 09-08-2011, 01:28 PM
Z06phile
Z06phile's Avatar
Default Pfadt bars & pillow blocks installed
Just thought I would share some pics of these works of art. I'm trying the HR front and LR rear since this is primarily an autocross car. We're doing a TNT later this month, so I'll be able to make adjustments to the coilovers and bars, play, repeat
The front bar is about 2# heavier than stock. The rear felt about the same as stock if not lighter. Sorry I didn't weigh it.
-Dan
Old 09-08-2011, 07:11 PM
mountainbiker2
mountainbiker2's Avatar
Let's us know how it works out.
Steve A.
Old 09-09-2011, 10:54 AM
waddisme
Support Corvetteforum!
waddisme's Avatar
They look awesome, even on the car. FYI - you might want to add retorquing the arms to your maintenance list. They don't mention that in the instructions. Those arms have been known to walk off.
Old 09-09-2011, 11:42 AM
Pfadt Racing
Pfadt Racing's Avatar
Looking awfully good on the car there! Let us know how they're performing for you! Looks like you got the Popp bar package.
Old 09-09-2011, 12:47 PM
Z06phile
Z06phile's Avatar
Steve A.
Will do.
Thanks for the heads up!
Thanks! Nice job on the bars. Adjustments will be easy.
Old 10-14-2011, 01:29 PM
Z06phile
Z06phile's Avatar
Here's the follow up:
I got to make 29 runs total over two days. 10 TNT runs on my street set, 10 TNT and 9 points event runs on the 315/18x4 A6s. I was 3rd out of 32 raw and 7th pax. Only .1 behind 2nd. These are the same drivers I battled with in my S2000, so I know where I stand. They used to beat me by a bigger margin, so I'm pretty happy about that. As you can see in the videos, there's a lot left in the car. I babied the launches and never really had any drama.
Course: decent concrete, 1320'x150'
Front HR bar: 2/3
Rear LR bar: 1/3
Front Pfadt SA coilovers: 14/16
Rear " ": 6/16
Front 315/18 A6: 31 cold
Rear " ": 27 cold
Tire temps (w/ probe) were in the mid 120s and were even across the patch except for the right rear. All I can figure is the hard right carousel caused some spin and I may need to go to 3/3 on the front bar. The inside of that tire was 5-6 deg higher than the left rear.
TNT:
http://www.youtube.com/user/Z06phile.../0/hgrT6du5E0E
Points event:
http://www.youtube.com/user/Z06phile.../4/bM-ULUJ9ONs
Hope to play on asphalt this Sunday with the PCA.
To Pfadt bars & pillow blocks installed
Quick Reply: Pfadt bars & pillow blocks installed
