Torque specs for Wilwood SL6R mounting etc?
Is there at torque spec for the 11mm 12-pt jet-nut that holds the caliper to the mount bracket? I put them good n' snug with some of Gary's nordlocks... about 15 ft/lbs.
Also, what about the caliper bridge insert/bolt that keeps the pads in? I put that in good n' tight with my 1/4" ratchet. Is that something that needs to be tight to the point of checking up? The aluminum sleeves the bolt goes through both spin freely.
This is my first set of fixed calipers on a Corvette so any guidance would be greatly appreciated.
I have been using my Wilwoods for about 2 years. The kit did not have any torque specifications on the caliper to bridge bolts. 15 Ft lbs will be more than enough. The forces are all radial (shear) on those bolts rather than vertical (tension) against the nuts. On the bolt that holds the pads in the caliper, same thing, no spec was provided. That bolt has a Nylok nut on it, it will not come loose. Just snug it up and you will be fine as long as the aluminum tube rotates freely. You are going to enjoy the new brakes !!!
Former Vendor
I am installing the wide pad version on the M3 race car we are nearly done building(father and son project, my son has bugged me for years to build a BMW, I am starting to like this car and have not driven it on track yet
Info taken from install guide for the BMW, should be exactly the same for your kit.
Caliper mount to spindle, 65 ft lbs
Caliper to bracket nuts, 30-35 ft lbs
Bridge bolt, not listed, just says not to tight, I will probably use the same setting as the rotor to hat bolts, 85 in lbs.
I have installed a set like this on another car and if I recall, 85 in lbs worked fine on the caliper bridge bolt.
Hope this helps
Rick
Hope this helps
Rick
Thanks Guys. I torqued the bolts holding the bracket to the spindle at 85 ft/lbs with nordlocks. The factory torque spec on those bolts is 125 but I didn't want to damage the aluminum of the adapter bracket. The adapter bracket in my kit is the custom LG one to use stock rotors.
I'll bump up the torque on the caliper bracket nuts a little and re-check the bridge bolt nut.
Hope this helps
Rick
Hope this helps
Rick
i use 80 for caliper bolt, 32 for the nut hoding the caliper to the adpater bracket.
i believe instructions call to "lightly oil" the stud that the nut goes on, I don't bother, but i do put high temp locktite on the caliper bolt
