what oil pan for a c4?
Old 09-28-2011, 06:01 PM
motodog
motodog's Avatar
Default what oil pan for a c4?
looking for a oil pan. block is a 4bolt with a 2pc rmc, 383ci. canton 7qt? what do you use? any issues? thanks racers. motodog
Old 09-28-2011, 09:39 PM
jaa1992
jaa1992's Avatar
Location: Life is just one big track event. Everything before and after is prep and warm-up and cool-down laps GA
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '12
Look in the C4 tech section. There are at least a couple guys using a Champ pan.
On my next build I'm waffling between a dry sump system or a road race pan and an accusump.
Old 09-28-2011, 09:41 PM
Rednels
Rednels's Avatar
I run a canton road race pan and an accusump. Let me know if you need me to dig up the part number for the pan.
Old 09-28-2011, 09:43 PM
Carolina C4 Racer
Carolina C4 Racer's Avatar
I put a Canton pan on my 92 over 10 years ago. Money well spent!
Old 09-28-2011, 09:56 PM
USAsOnlyWay
USAsOnlyWay's Avatar
I've got a Canton 240t or something like that. The 7qt road race. A couple of guys have claimed they had leaks from them and were trying some other pans (thread in C4 Tech). So far so good for me...
Old 09-28-2011, 11:22 PM
motodog
motodog's Avatar
thanks, i will most likley get the canton, the dry sump setup is way out of my $ range.
Old 09-29-2011, 12:07 AM
Crepitus
Crepitus's Avatar
If you using headers you might want to check on header and starter compatibility. Be sure the pump / pickup is right as well. I am thinking about using a remote filter and cooler where the battery used to be. Then adding pan capacity where the filter used to be. I will be choosing a pan this winter myself.
Old 09-29-2011, 03:17 PM
BrianCunningham
BrianCunningham's Avatar
Location: Boston, Dallas, Detroit, SoCal, back to Boston MA
Canton + accusump here
Old 09-29-2011, 03:48 PM
Rednels
Rednels's Avatar
For what its worth, my canton leaks. I have had 2 now, first one was fine. Second one is leaking.
Old 09-30-2011, 11:33 AM
ScaryFast
ScaryFast's Avatar
Yeah, Canton quality is suspect. I have one on my C4 and it's been a PITA. I've had it off several times, fluxed it, welded it, etc. It still freakin' leaks at the fill plug.
I'd take a look and see if anyone is having better luck with a different brand, maybe the Milodon or another.
I have not had any header, filter, or starter issues with the canton pan.
To what oil pan for a c4?
Quick Reply: what oil pan for a c4?
