Urgent help required. C5 tech gurus please assist.
Old 10-06-2011, 07:56 PM
wallyman424
wallyman424's Avatar
Default Urgent help required. C5 tech gurus please assist.
So I've plugged everything in, and I gave it a crank.
It cranks freely, but does not fire. There is fuel in the rail. Its spitting out codes P1275 and P1276. I have no idea where to go from here.
Please help.
UPDATE: Already fixed guys. Thanks for the suggestions. It was a bad ground connection.
Old 10-06-2011, 08:05 PM
RX-Ben
RX-Ben's Avatar
I assume you know these are (gas pedal sensor issues):
P1275 APP Sensor 1 Circuit
P1276 APP Sensor 1 Circuit Performance
Info on the system, w/schematics and pictures:
http://chevythunder.com/drive_by_wire.htm
Check voltage/continuity/plugs/etc.
Old 10-06-2011, 08:17 PM
wallyman424
Yeah, but the gas pedal was fine before all this stuff, it just doesnt make sense that it would have up and died.
Old 10-06-2011, 08:25 PM
drivinhard
Support Corvetteforum!
drivinhard's Avatar
I think I've got a spare TAC module and gas pedal/APPS if you think it's related. Can bring to VIR.
All grounds good?
And stupid question, but is the TB servo connector hooked up and tight?
Old 10-06-2011, 08:26 PM
wallyman424
Fixed it. I'm smarter than the GM manual.
SEE ALL YOU SUCKERS AT VIR
Old 10-06-2011, 08:27 PM
BERETTA
BERETTA's Avatar
Check the throttle actuater fuse (tac) in the underhood fuse/relay box first..
Old 10-06-2011, 09:40 PM
davidfarmer
davidfarmer's Avatar
2 of the wiring harness's have the same connectors, and I've plugged them opposite before. Cranks but no fire.....
Old 10-07-2011, 07:09 AM
Bills Z06
Bills Z06's Avatar
St. Jude Donor '07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18
Glad you got it going!
Old 10-07-2011, 07:15 AM
Jason
Jason's Avatar
CI 4-5-6-7 Veteran
That's what I'm talking about.
Old 10-07-2011, 12:02 PM
sperkins
sperkins's Avatar
I say it's a bad ground connection.
Old 10-07-2011, 12:03 PM
wallyman424
Put out 2 more "fires" this AM.
1. Forgot to put those little water crossover plug blocks on the back of the head. Luckily they can go on without removing anything
2. Was overheating at idle. Required very aggressive burping maneuvers to get the air bubbles out. Now idles cool.
At work now. Car should be ready after a couple more hours of labor this evening, then I can haul out to VIR.
To Urgent help required. C5 tech gurus please assist.
Quick Reply: Urgent help required. C5 tech gurus please assist.
