C5 spring rates - going HIGHER on front?
#81
My current setup is C5Z springs, DRM Bilstiens and C6Z bars. Would I gain anything by going with a slightly stiffer front spring only, like a VBP Sport front spring? I do feel the car understeers at times but its very predictable and controllable. I run in a dot street tire class so Im on Toyo R888's.
#82
If it were me, I'd probably leave it as slight understeer is safer on a road course, but if you're auto-xing then I'd go to a softer front bar like a C5z.
I'd also get the car on scales if you haven't done that lately, you could be chasing a simple cross weight problem.
#83
What tire widths are you on? I'd expect that setup to oversteer unless you have some pretty wide rear tires with the c6z bars.
#84
#85
Run a square set up before switching out springs. The staggered setup is suppose to balance towards understeer.
