Next step in my never ending build sheet
Old 10-26-2011, 12:04 AM
Gman57
Gman57's Avatar
Default Next step in my never ending build sheet
Well season is over for most in the central/northern areas. I can't stay idle for long. I made the commitment two months ago to take my C6Z to the next level. With the help of DRM this will be a contender in NASA TTU class. Should make 550-560 RWHP and have all the bells and whistles... the rest will be up to me
This is and add-on from last winters build list and this years mods consist of the following......
Forged & coated JE pistons, ported heads, cam, rods, valves, springs, rod and main bearings this should add around 90RWHP for a total around 560 RWHP.
New Davis cooling system with 2 stage oil, trans and diff cooler, RPS dual carbon clutch, DRM coilover package, Alcon race brakes, APR rear wing and Rear half of the cage.
A few pics of the cage fab to start with and I'll add more as it goes.
Cage is being fitted and tacked in place in the following shots
More to follow as the build goes on
Old 10-26-2011, 02:32 AM
Gering
Tolero Apto Victum
Support Corvetteforum!
Gering's Avatar
OP: Nice Red Vet!
Old 10-26-2011, 08:52 AM
CHJ In Virginia
CHJ In Virginia's Avatar
That is going to be one Fast and Safe car once DRM finishes the job. Keep us informed as the build progresses.
Old 10-26-2011, 09:30 AM
Short-Throw
Short-Throw's Avatar
Gary,
Buying a cage is the best money you can spend on a track car. May it be a moot point and never get tested.
Keep an eye on Randy up there and remind him you don't need any spiked tires for ice racing.
Mike
Old 10-26-2011, 09:46 AM
SDF
SDF's Avatar
Awesome Gary! Your car is in good hands! Can't wait to see the finished product.....................Remember I know a good test driver .
See ya,
Scott
Old 10-26-2011, 10:50 AM
Gman57
Gman57's Avatar
Mike
Mike-
Randy did the hard sell on the spiked tires but I told him the ice never gets thick enough around here to get the car out in the winter
Although it would be nice to do a little shake down on the car when it gets home
Take care
G
PS.... Scott I know where to find you in the spring
Old 10-26-2011, 10:54 AM
travisnd
travisnd's Avatar
Any pics of how they're attaching the steel cage to the aluminum frame? Glad they went through the rear wall... only right way to do it in these cars
Old 10-26-2011, 11:00 AM
Gman57
Gman57's Avatar
That may be a DRM secret .... let's see if Randy drops in.
Old 10-26-2011, 11:21 AM
travisnd
travisnd's Avatar
Always interesting to see how different shops do it... not trying to leak any trade secrets though
Looks like the rear section of my cage is very similar to yours, but I don't have those two lower side bars going from the main hoop back to the rear anchor points and my car is steel
Old 10-26-2011, 12:21 PM
0Randy@DRM
Former Vendor
Randy@DRM's Avatar
My picture posting does get watched over by big brother (AKA Boss-father) Basically sleeved, bolted and backing plated.
Randy
Old 10-26-2011, 12:29 PM
0Randy@DRM
Former Vendor
Randy@DRM's Avatar
Don't worry guys no spiked tires on this one. 1200 dollar fenders wouldn't work that well. I have a new ice racing car in the works, the only problem is 1 hour of working on it a month it's going to take 68 years to finish it
Randy
Old 10-26-2011, 05:14 PM
MySR71
MySR71's Avatar
Randy, Todd, and company worked on my car this past Spring and Summer (roll bar to full cage, suspension overhall, and a number of other items). Everyone was great to work with despite my being fairly particular on what I wanted. I'm thrilled with the results. You picked a great shop to do the work.
Old 10-26-2011, 05:30 PM
Gman57
Gman57's Avatar
Yep... I believe I saw your car up there this last spring when I had the headers and other things installed. And your right the DRM guys rock
Old 10-26-2011, 06:20 PM
AtomicZ
AtomicZ's Avatar
DRM cage work is world class.
Old 10-27-2011, 09:50 PM
Gman57
Gman57's Avatar
Got a sneek peak at the new brakes. The name Alcon I know is not the bead and butter name that alot here would think of for brakes but with a background like NASCAR, ALMS, F1, INDY and recommended by DRM I should be in for a great package. The install will include their purpouse built master cylinder for a supper ferm pedal
A couple of snaps below
front
rear
G
Old 10-27-2011, 10:01 PM
travisnd
travisnd's Avatar
I think you can safely assume anyone into racing knows who Alcon is
Old 10-27-2011, 10:28 PM
Gman57
Gman57's Avatar
...... and not made in China or Taiwan
To Next step in my never ending build sheet
Old 10-27-2011, 11:52 PM
Gering
Tolero Apto Victum
Gering's Avatar
Nice pics as well.
Old 10-27-2011, 11:57 PM
BFoster
BFoster's Avatar
<--- jealous guy here!!!
Old 10-28-2011, 01:25 AM
dvandentop
dvandentop's Avatar
nice maybe i will have to swing by and check on it for you
they can practice doing the cage on your z and maybe i should have em do mine too
Quick Reply: Next step in my never ending build sheet
