Anyone use Ferodo brake fluid?
http://www.racerpartswholesale.com/p...8/Brake_Fluid2
This is for autox & DE, not TT or racing.
I have been using Wilwood 570 prior with no problems, but the price has gone up.
SRF fans, yes, I know, but I would rather do several flushes a year, that's just my thing.
I've been using the Ferodo Super Racing brake fluid which is supposed to have a 626 degree dry boiling point and its worked well for me. That and Hawk DTC-70 pads and my pedal has been solid even through an entire 45 min race without the slightest bit of fade.
Supporting Vendor
Ferodo brake fluid is excellent. The fluid for sale in that link is the older version of their product, but it is an outstanding buy at the price listed.
The new version of the fluid has enhanced specs, with a higher boiling point (626F vs. 572F). We are getting great feedback from this fluid from professional race teams.
Again though, that is a great deal for an excellent fluid at that price.
Wonder why it isn't recommended for regular road use?
I've always used Motorcraft high performance brake fluid from my local Ford dealer with good results. A couple of years back they reduced the dry boiling point spec from 550 to 500 on it but the performance didn't seem to change for me. I just flushed before a track day and continued to run it till the next track day.
IF you change say, yearly, I think it'll work great in a street car.
Anyone else?
BTW I used the Ford stuff for years, but when I started DE's I wanted a little more cushion. Wilwood 570 was my choice for a couple of years @ about 6 bucks a bottle (bulk) but I can't find it anywhere for less than 9-10 bucks.
Ordered 10 bottles today, Ferodo.
I got 10 bottles today
Ferodo
Formula
Racing Brake Fluid
The older version.
Made in UK
It has not DOT equivalent rating, which is fine, but I just want to ask if it's dot3/4 equivalent fluid based on it's own testing process.
I saw one inet rating that said it's 5.1 equivalent, but I really don't know.
There is nothing on the label that says DOT anything
The part # is DSF 050A
I want to make sure it's not the SYNTHETIC brake fluid that we are not supposed to use.
Thanks.
Update on this fluid and a question.
Ferodo
Formula
Racing Brake Fluid
The older version.
Made in UK
Thanks.
Ferodo
Formula
Racing Brake Fluid
The older version.
Made in UK
Thanks.
If we can figure out the DOT equivalance then the your questions may be answered.
I have always mixed dot equivalent brake fluids (50 years) and I do recommend a full flush to start out (for track use).
I would not use this in a street car unless you do an annual flush. There is no wet rating on the bottle.
Boiling point
Brake fluid is subjected to very high temperatures, especially in the wheel cylinders of drum brakes and disk brake calipers. It must have a high boiling point to avoid vaporizing in the lines. This vaporization is a problem because vapor is compressible and negates hydraulic fluid transfer of braking force.
Quality standards refer to a brake fluid's "dry" and "wet" boiling points. Wet boiling point, which is usually much lower (although above most normal service temperatures), refers to the fluid's boiling point after absorbing a certain amount of moisture. This is several (single digit) percent, varying from formulation to formulation. Glycol-ether/dot three/dot four/dot five point one brake fluids are hygroscopic (water absorbing), which means they absorb moisture from the atmosphere under normal humidity levels. Non-hygroscopic fluids (e.g. silicone/DOT 5-based formulations), are hydrophobic, and can maintain an acceptable boiling point over the fluid's service life, although at the cost of potential phase separation/water pooling and freezing/boiling in the system over time - the main reason single phase hygroscopic fluids are used.
Boiling points for common braking fluids [1]
Dry boiling point
Wet boiling point
DOT 3
205 °C (401 °F)
140 °C (284 °F)
DOT 4
230 °C (446 °F)
155 °C (311 °F)
DOT 5
260 °C (500 °F)
180 °C (356 °F)
DOT 5.1
270 °C (518 °F)
190 °C (374 °F)
Wet boiling point defined as 3.7% water by volume.
The health warning says contains polyalkylene glycol ether esters.
Does that make it a glycol-ether based fluid?
I would think so.
Boiling point
Dry boiling point
Wet boiling point
DOT 3
205 °C (401 °F)
140 °C (284 °F)
DOT 4
230 °C (446 °F)
155 °C (311 °F)
DOT 5
260 °C (500 °F)
180 °C (356 °F)
DOT 5.1
270 °C (518 °F)
190 °C (374 °F)
I would think so.
