Question about gmpp estimate for repair
Old 11-01-2011, 02:19 PM
froggy47
froggy47's Avatar
Default Question about gmpp estimate for repair
Car is in a non dealer/independent shop for engine oil leak. The gmpp inspector approved the repair but will only pay about 1/2 the hours that the shop estimates it will take to do the job.
Do I have to go "shopping around" to find a repair shop that will do it for less?
Do I have any other recourse?
Thanks.
It's a front engine cover gasket & upper oil pan gasket.
Appraiser says 6 hrs @$95 and the shop says 12 hours same rate.
Update,
There was a misunderstanding between the appraiser & the shop, the allowed claim is about double what the shop originally thought.
I hope the mechanical goes smoother than the paper work.
I had to call the adjuster & sort it out.
feh
Quick Reply: Question about gmpp estimate for repair
