Aero Project...
Old 11-01-2011, 06:04 PM
BERETTA
Support Corvetteforum!
BERETTA's Avatar
Default Aero Project...
Well I am diving into the aero world! This stuff really is interesting, I have been trying to take pictures as much as I can during the process.
First of all I would like to thank some of the forum members that I have messaged for questions here and there, this forum is a great place
I decided to go wth the Kognition Wing, again based on a lot of research here on the forum. The folks at Kognition were very good to deal with and got the wing to me as fast as they could due to the dead line I am working on.
As far as the front end, hood, and splitter- again after research here I felt like it had to be ACP. Kerry Hitt also was very helpful and is extremely knowledgeable on our cars and has tested with GM in the tunnel. He actually got the parts to me 3 days ahead of what I requested- outstanding! He has also been available to me for any questions I have had. Kerry You I am adding some pictures now to get caught up with where I am right now, I hope to finish this project in another week or two. I will add more pictures as i go.
The mounting brackets were fabricated out of 5x3 angle lightened down to about 5 lbs each. (There are two more bolts that go in the lower mount just not in at the time of the photo)
I am going without fans first time out- If I do have to go back to a fan it want be with the factory boat anchor set-up
To be continued
Old 11-01-2011, 06:31 PM
Wasserott
Wasserott's Avatar
I thoroughly enjoyed the aero fabrication stuff! Have fun...
Old 11-01-2011, 06:54 PM
Jason
Jason's Avatar
CI 4-5-6-7 Veteran
Will be following this.
Old 11-01-2011, 06:56 PM
drivinhard
drivinhard's Avatar
what's the fascia/splitter weigh?
looks good, you gonna run it in Dec at RA?
Old 11-01-2011, 07:04 PM
varkwso
varkwso's Avatar
Very good info. Thanks.
Old 11-01-2011, 07:15 PM
0Louis @ LG Motorsports
Former Vendor
Louis @ LG Motorsports's Avatar
Make sure that you can step on the splitter when you are done, or youll be re-doing this thread!
Old 11-01-2011, 07:39 PM
Jason
Jason's Avatar
CI 4-5-6-7 Veteran
How does the splitter attach and transfer the downforce on it to the frame?
Old 11-01-2011, 07:48 PM
Gman57
Gman57's Avatar
Looks great!!!
Old 11-01-2011, 07:52 PM
BERETTA
BERETTA's Avatar
I do not know the weight of the splitter/fascia, I will have it all back off several more times, I will try to get the weight. I have lifted the fascia/splitter/undertray all attached together and I would say it is close to the factory front nose with parking lights etc. I did get the splitter and front fascia in two pieces, hopefully in the event of an off track event it will only take out the splitter and not damage the front fascia too bad of course the undertray is also in jeopardy
Here is a picture of the splitter before I attached it to the fascia, it weighs practically nothing. The undertray is carbon so it is very light, the splitter and fascia are fiberglass..
Can't make Rd Atl. this year
Old 11-01-2011, 07:58 PM
BERETTA
BERETTA's Avatar
Thanks, that is what I have been told. I remember reading that Raftracer said he could jump up and down on his. I have adjustable rods ordered for the splitter and I am also adding some bracing from the front frame to the splitter/fascia I will see how strong it is then...
Old 11-01-2011, 08:12 PM
sperkins
sperkins's Avatar
:drool:
Old 11-01-2011, 08:20 PM
jtmck
jtmck's Avatar
Dennis,
You have now entered the dark side.....
BERETTA
BERETTA's Avatar
Jason just a partial answer here the undertray has aluminum plates molded into the carbon fiber, I drilled and tapped these 1/4 20 and used stainless bolts through the splitter into the carbon fiber undertray, this ties everything together. Also as mentioned above I am fabricating some supports to attach the splitter and fascia to the front frame section. The rear of the undertray attaches to some brackets that are now welded to the sway bar mounts. This also allows for a little bit of adjustment in the undertray vertically about an 3/4 of an inch. Here is the best picture I have right now at the back of the undertray, I will take more later
Old 11-01-2011, 08:33 PM
travisnd
travisnd's Avatar
Color me jealous
EDIT - Just noticed you still have the factory antenna installed. FYI the OEM rubber hood bumpers make a perfect plug for the antenna grommet
TRAKOUT (01-29-2020)
Old 11-01-2011, 08:54 PM
gmccreary
gmccreary's Avatar
Very nice Dennis. Looks like you went off the deep end.
Old 11-01-2011, 09:04 PM
BERETTA
BERETTA's Avatar
Originally Posted by travisnd
Color me jealous
Thanks Brian...
Good idea on the antenna got a picture?
Old 11-01-2011, 10:17 PM
John Shiels
John Shiels's Avatar
Location: Buy USA products! Check the label! Employ Americans
Get the side skirts from Kerry too!
To Aero Project...
Old 11-01-2011, 11:35 PM
BERETTA
BERETTA's Avatar
Thanks!
Yes I did, I am still trying to wiggle the hook free
Old 11-02-2011, 12:46 AM
travisnd
travisnd's Avatar
Old 11-02-2011, 12:48 AM
sperkins
sperkins's Avatar
More aero drag than a 1/4-20 stud.
Quick Reply: Aero Project...
