R 6 question
Old 11-04-2011, 11:22 AM
JohnAlley
JohnAlley's Avatar
Default R 6 question
Just finished my first few session on the Hoosier R6's after running only on street tires and have a question. I did cord the tires around the outside edge which I have been told is from not enough negative camber. My questions is what would cause a large amount of track rubber build up around the middle of the tire? Too much air or not enough? 3 out of the 4 tires have a large bead of old rubber down the middle of the tire all the way around.
Old 11-04-2011, 11:31 AM
beerkat
Support Corvetteforum!
beerkat's Avatar
I will be running R6's for the first time next weekend. I plan on using 22 to 26 psi in front and 18 to 24 psi in the rear. I am getting my car's alignment change to -2.5 to -3 in front and -1.5 or -2 in the rear. How does your setup compare.
Old 11-04-2011, 11:34 AM
RacePro Engineering
RacePro Engineering's Avatar
That's simply how soft compound tires cool sometimes. That excess rubber will sluff off as soon as they are run next time, provided they were not corded.
Typically, one can determine if the inflation pressure was correct by watching the scrub across the surface of the "tread": scrub complete to outside and inside = not over-inflated. Unfortunately, since your camber was off, this read will not be very reliable.
The best way to determine optimum pressure is with a probe pyrometer, and a search here will give you much info on the topic. However, that work will be useless until you get negative camber in the correct range.
Ed LoPresti
Old 11-04-2011, 11:44 AM
95jersey
95jersey's Avatar
Totally normal, I get rubber somtimes in one specific place or all over the entire tire. That is just where you happened to pick up rubber, nothing more, nothing less.
Old 11-04-2011, 02:30 PM
jawfixer
jawfixer's Avatar
I am running similar camber on front and rear and run28-30 in front and 26-28 rear and shooting for the 33-34 range when hot. Without a pyrometer and many checks , we are only guessing what is best. I think 22 front and 18 rear is too low, just guessing. I run thru about 3 sets of R6's a season--I change before they cord--usually when they are greasy.
Old 11-04-2011, 02:35 PM
JohnAlley
JohnAlley's Avatar
I started with the cold tire pressure I got from Hoosier. I am looking to go with -3 front and about -2.5 rear for next year.
Old 11-04-2011, 03:56 PM
sperkins
sperkins's Avatar
I'd be surprised if you can get that much in the rear. I can only get -1.3L and -1.5R.
Old 11-04-2011, 04:20 PM
AU N EGL
AU N EGL's Avatar
Too much.
20-22 front COLD 28 HOT 30 becomes too greasy and slippery
18-20 rear COLD 28 HOT
depending on how you run, but still shoot for the ~28 HOT
as they age even lower
Old 11-04-2011, 08:29 PM
jlutherva
jlutherva's Avatar
Any thoughts on the number of heat cycles you can get out of R6's before they lose traction?
I'm thinking 32 might be too many.
Jim
Old 11-05-2011, 07:57 AM
AU N EGL
AU N EGL's Avatar
32 on HOW MANY SETS?
Old 11-05-2011, 08:07 AM
beerkat
beerkat's Avatar
I think that I can get -1.5, I think that I have had that much before. I was just hoping for the -2.
Probably should have said I will run as much negative camber as the car will give me.
Old 11-05-2011, 08:37 AM
SouthernSon
SouthernSon's Avatar
Location: Deal's Gap 2004 NCM Motorsports track supporter
Received 1,103 Likes on 717 Posts
John, are you running polyurethane bushings?
Old 11-05-2011, 09:23 AM
AU N EGL
AU N EGL's Avatar
the GM T1 or HardBar concentric / camber blocks should get you -2.0* for the rear and -3.0* front
Old 11-05-2011, 11:10 AM
JohnAlley
JohnAlley's Avatar
Not yet everything is still stock as it came from factory. I am planning on doing the Pfadt heavyweight front and rear sway bars as well as the pillow blocks. Do you suggest I go with the poly bushings also ? Have sent Danny a few e-mails w/o any response. I am looking at doing the light weight clutch this winter, will most likely hold off on the cage until 2013 ( need more experience before I step up to the big league)
Old 11-05-2011, 01:34 PM
GT Racing Tires
Supporting Vendor
GT Racing Tires's Avatar
Good advice from everybody. You will need poly bushings for the negative camber to work properly. With stock stuff once you turn in your camber doesn't hold.
Old 11-05-2011, 08:29 PM
NVR2L8
NVR2L8's Avatar
That would be about three sets for me, especially the fronts.
Old 11-05-2011, 08:45 PM
sperkins
sperkins's Avatar
You need a set of my custom camber blocks.
To R 6 question
Old 11-06-2011, 07:30 AM
beerkat
beerkat's Avatar
If they add points I can not use them. I already had to put a stock air box on my car to get a point back so I could run R6's.
Old 11-06-2011, 09:22 AM
WNeal
WNeal's Avatar
Cruise-In Veteran VII
Cruise-In Veteran VIII
"Slower Azz Dog"
St. Jude Donor '06-'07-'08-'09
John,
That usually happens at track speeds under 50 MPH.
Step it up next time and that won't happen
Old 11-06-2011, 09:30 AM
jlutherva
jlutherva's Avatar
Well, that would be one set of rears. I'm new to race tires. Last time out it was all I could do to get them around T1 at VIR. I found a couple of good coaches that helped me adjust air pressures but each session just got worse after a couple of laps. At the end of session 4 on day 2, the rears were corded. I should also add that the negative camber was not correct.
So how many heat cycles can an R6 take before performance goes away?
Some one indicated 32/3 -10? Maybe I should b asking what a heat cycle is - one hpde session? If so, that's a new set of R6's for every HPDE That's not in my budget.
Jim
Quick Reply: R 6 question
