Leaking Axle Seal, GM Seals OK for Track?
Hey all, just wondering if the track guys have a better solution than replacing leaking axle seals with the GM seals. I know they are an updated PN, but still seem to leak. Thanks.
Location: If you don't weigh in you don't wrestle Road America
I've come across this several times, typically it's a groove that's worn into the 1/2 shaft itself - I buy used 1/2 shafts for $125 - $150 and swap it out with a new side seal - so far I've fixed 4 cars by doing both.
