Winter project on the way
Old 11-09-2011, 09:51 PM
ssdeuce
ssdeuce's Avatar
Default Winter project on the way
After having to back off while having the time of my life because of 300 degree oil temp I pulled the trigger tonight on DRM's track only oil cooler. Can't wait to get it installed so I'm hoping for a mild winter here in Tennessee
Old 11-09-2011, 10:03 PM
Gman57
Gman57's Avatar
DRM Rocks
Old 11-10-2011, 09:23 AM
travisnd
travisnd's Avatar
I've got their kit with the larger 625 cooler. Hottest the car got all summer was 257 and that's with 10w40 oil and a high volume oil pump keeping pressure up which can cause higher temps vs. stock and lower viscosity oil.
Old 11-10-2011, 11:41 AM
ssdeuce
ssdeuce's Avatar
I got the 625 cooler also I use 10w40 too. I was pushing it back in the summer having to take a lap or two off every few laps. I hope that means my driving is getting better :-)
To Winter project on the way
Quick Reply: Winter project on the way
