Fan information needed...
Old 11-12-2011, 06:02 PM
Falcon
Falcon's Avatar
Default Fan information needed...
I'm going to remove the factory radiator fans and need info from you guys who have installed aftermarket fans.
What kind/size is adequate?
Old 11-12-2011, 06:05 PM
drivinhard
Support Corvetteforum!
drivinhard's Avatar
I did the little 13" SPAL. 6 lbs I think. works great
Old 11-12-2011, 06:13 PM
Falcon
Falcon's Avatar
Thanks!
Did you fabricate a bracket to hold it or did you use the radiator zip tie things?
Old 11-12-2011, 06:29 PM
drivinhard
drivinhard's Avatar
Originally Posted by Falcon
Thanks!
just did the zip ties, they are lighter than brackets
Old 11-13-2011, 12:07 AM
trackboss
trackboss's Avatar
I got the highest flowing 16" spal rated for continuous duty. I hammer formed some simple brackets that I welded to the radiator and installed threaded inserts in the fan housing. Two screws and it's secure. Ignore the rest of the cooling as it is a custom setup I built, but no reason you could't do a similar fan setup on a stock type radiator. I even used the factory wiring with a few simiple modifications.
Old 11-13-2011, 11:46 AM
RX-Ben
RX-Ben's Avatar
I have this ($50 used on ebay) - http://www.jegs.com/i/Flex-A-Lite/40...0002/-1?CT=999
2500cfm is overkill - even in NYC traffic while towing my tire trailer.
Old 11-13-2011, 04:43 PM
geerookie
geerookie's Avatar
I bought a used 16" SPAL from one of the Nascar recycling places for $49.
I fabricated an aluminum bracket and it weights more than wire ties and somehow my car still weighs less than Mark's
It is overkill but it only weighed about 5.5lbs so what the heck.
Old 11-13-2011, 08:03 PM
sperkins
sperkins's Avatar
What kind of radiator are you running Jody?
Old 11-13-2011, 08:21 PM
geerookie
geerookie's Avatar
He probably just borrowed the swamp cooler off of his neighbors house
None of that fancy name brand some for him....
Old 11-13-2011, 08:27 PM
Falcon
Falcon's Avatar
A Ron Davis radiator.
I was talking to a guy up here who just built a fabulous sand buggy and he said he bought his radiators for the stuff he builds from a company called Universal. I saw what he had them build and it was gorgeous and 1/2 the price of a Ron Davis.
Old 11-13-2011, 08:30 PM
Falcon
Falcon's Avatar
If I hurry up and get it reinstalled, he'll never know I took it.
BTW, Gee, what is the plastic stuff you have on the leading edge of your front fenders for aero, and where did you buy it?
To Fan information needed...
Quick Reply: Fan information needed...
