davidfarmerstuff.com update
almost that time of year again, your generous donations help keep my site alive. I also noticed that I haven't posted links in a while.
So make copies, laminate, and keep them handy. I'll post direct links to some of the most popular below. There are also ARP studs sheets, brake fittings, trans/diff fitting sheets etc.
**btw, someone requested I make a torque spec sheet for the ZR1, but I no longer have access to the GM Service website. If anyone can get me in, I'm happy to put all the data together into a pdf.
Thanks!
http://www.davidfarmerstuff.com
http://www.davidfarmerstuff.com/C5torque.pdf
http://www.davidfarmerstuff.com/C6-Torque-Manual.PDF
http://www.davidfarmerstuff.com/C6Z06-Torque.pdf
http://www.davidfarmerstuff.com/align.pdf
Consider a small donation, or buy some stickers! Every bit helps. Thanks
Thanks!
I now host them on my dropbox.... and use my facebook page. You are welcome to replace the links, or delete them...
http://www.facebook.com/DavidFarmerRacing
https://dl.dropboxusercontent.com/u/...6/C5torque.pdf
https://dl.dropboxusercontent.com/u/...que-Manual.PDF
https://dl.dropboxusercontent.com/u/...Z06-Torque.pdf
https://dl.dropboxusercontent.com/u/1634366/align.pdf
https://dl.dropboxusercontent.com/u/...6/accusump.pdf
https://dl.dropboxusercontent.com/u/1634366/c5-dtc.pdf
https://dl.dropboxusercontent.com/u/1634366/c5-fuse.pdf
https://dl.dropboxusercontent.com/u/...amberplate.PDF
https://dl.dropboxusercontent.com/u/1634366/diff.pdf AN adapter for metric diff
Thanks!
