C5 or C6 Differential for C4 adapter
Old 11-14-2011, 04:39 PM
Coconut
Coconut's Avatar
Default C5 or C6 Differential for C4 draveshaft adapter
I'm looking for either:
1) An adapter to connect a C5 or C6 Corvette differential to a regular drive shaft instead of a torque tube?
OR
2) something that will allow a Dana 44 to fit on a C5 or C6 Corvette suspension cradle?
I've seen both of these done before, but I'm not sure where to locate the actual parts. I'm really interested in option 1.
Here's a pic for option 2 at Street Shop, Inc. The side yokes would help much. I can get the rear diff cover.
Old 11-15-2011, 04:38 PM
shakedown067
shakedown067's Avatar
St. Jude Donor '12-'13
No clue, but that's one nice piece of work in the photo you posted. Very cool project.
Old 11-15-2011, 06:10 PM
Zip Corvettes
Platinum Supporting Vendor
Zip Corvettes's Avatar
How much do you want to spend?
Old 11-15-2011, 06:21 PM
SteveDoten
SteveDoten's Avatar
Cruise-In VII Veteran
looks like C6 L/UCA's on that frame
C5/6 diff to driveshaft? has this been done? I think the Dana44 would be the better route, better looking also
Old 11-16-2011, 05:56 PM
Coconut
Coconut's Avatar
Default Viper
Yes. it has been done before.
That particular differential is from a Viper Dana 44.
Old 11-16-2011, 06:02 PM
Coconut
Coconut's Avatar
Default Hmmm
I'm not sure, but an adapter to connect the rear differential of a C5 or C6 to a drive shaft would save me time, headaches, & I'm sure would be cheaper in the long run than dealing with a torque tube.
Apparently, there was an adapter made by http://www.21stcenturystreetmachines.com/
back in 2005 at the Good Guys auto show in Charlotte, but that company's website is no longer in existence.
I know I have seen a billet aluminum adapter on a C5 differential at a website that builds modern chassis for old hot rods (like Art Morrison - just as an example), but I cannot remember where it was at, nor seem to find it online again.
Old 11-16-2011, 06:34 PM
Coconut
Coconut's Avatar
Default Possibly
This is not the adapter I saw somewhere online, but it does appear that Hot Rod Jim may possibly make one. I'm waiting to find out.
More information can be found at the following link (just scroll down toward the middle of the page): http://www.hotrodjim.com/projects_shop_57_truck.php
Old 11-16-2011, 06:38 PM
Coconut
Coconut's Avatar
Default Finally!!!
I finally found the image I saw online:
It is located at Chassis Concepts.com http://www.chassisconcepts.com/
They make the following:
Suspension
Adapters and parts
C5/6 Differential Adapter
New and Used C4/C5/C6
Suspension
Now, I just need to see if i can get me one!
Old 11-16-2011, 06:45 PM
Coconut
Coconut's Avatar
Default Get your name on the list!
All,
Hot Rod Jim is in the process of testing the adapter he has created for production. When it is ready, he will send out a notice. So if you need one, then email him, & get on the waiting list!
Old 11-16-2011, 07:38 PM
SteveDoten
SteveDoten's Avatar
It's in production with real world use?
why use the Getrag C5 over Dana?
Old 11-16-2011, 10:37 PM
Coconut
Coconut's Avatar
Default Suspension
I'm replacing the C4 rear suspension with the C5/C6 A-arm style. I can put a Dana 44 on it, but since I have every part (including the differential) for the C6, it's easier for me to just use a C5/C6 differential adapter for the drive shaft.
The original pic above shows the A-arm style rear suspension with a Dana 44 connected to it from a Viper. Without a doubt, it can be a strong rear setup!
The C6 differential with a drive shaft adapter just works better for my particular application at this time - that's all.
Old 11-17-2011, 12:01 PM
Coconut
Coconut's Avatar
Default Confirmed!
Suspension
Adapters and parts
Suspension
The above has been confirmed. The unit can be had for:
Retail is $1,325
The owner will be at the 2011 Turkey Rod Run coming up.
Old 09-28-2015, 12:11 PM
ktmcorvette
6th Gear
ktmcorvette's Avatar
Default Chassis Concepts Diff Adapter
Retail is $1,325
I have seen the Chassis Concepts Diff Adapter referenced in several posts, but I can't find much information about it. Even Chassis Concepts WEB page doesn't really have any info on it. Has anybody used one? Does it work very good? Any info would be appreciated.
To C5 or C6 Differential for C4 adapter
Quick Reply: C5 or C6 Differential for C4 adapter
