FS: Dewitts C5 direct fit radiator w/ right side EOC
Sold!!!
I have a new and still in the box, Dewitts direct fit radiator for the C5. It has an Engine Oil Cooler in the right side tank, which will cool the oil even more than a left side EOC.
The Dewitts part number is A97ER
There are no dings, no dents, and no damage what so ever. It is inside it's original box and i'm not gonna pull it out and risking bending fins or other damage to take pictures of a brand new radiator. I have posted pictures of it inside the box.
It is NOT being sold with any extras such as oil cooler hoses and block adapter. Even though this unit has a built in oil cooler, it does not have to be used.... just plug cap the fittings and use it without. If you want to use the built in oil cooler , you will need two 90 degree fittings, some #10 hose cut to length, and a block adapter and hose fittings to attach to it. The oil cooler hose and adapter kit that Dewiits sells will NOT work with a right side EOC. You have to do your adapter and hose yourself as I described.
What i need is $520 in my pocket after the deal is done. Any fees (shipping, PP, etc) above $520 is all on you. This price is $100 off what it sells new for, not counting shipping (which is another $45 from Dewitts). I won't take less...I will just install it in the car this spring if I still have it.,....SOLD!!!
http://i30.photobucket.com/albums/c3...oglecom7-1.jpg
http://i30.photobucket.com/albums/c3...oglecom8-1.jpg
http://i30.photobucket.com/albums/c3...oglecom9-1.jpg
