what underdrive pulley you guys run?
Old 11-19-2011, 10:57 AM
VGLNTE1
VGLNTE1's Avatar
St. Jude Donor '14-'15
Default what underdrive pulley you guys run?
i got a nice new powerbond 15% about 2 years ago...still in the box though. I heard to many horror stories about how they are not as balanced as a stocker and are known causes for timing chain breaks. Was wondering what your guys opinion was and what you run
thanks
Old 11-19-2011, 11:07 AM
Aardwolf
Aardwolf's Avatar
I put a March set on years ago and have recently went back to a smaller water pump pulley to speed it back up. Hopefully that will bring the coolant temps down some.
Old 11-19-2011, 11:48 AM
waddisme
Support Corvetteforum!
waddisme's Avatar
When I did my build 3 yrs ago, the underdrive seemed like the common denominator in the timing chain breaks for LS2. It seemed like too much risk for few more hp. But honestly, I haven't heard that much about it in the C6 Tech section anymore. Not sure if everyone has gone to the upgraded chain or what. I did the Issis timing chain. Good luck with it.
Old 11-19-2011, 02:48 PM
thehammer69
thehammer69's Avatar
thanks
I'm selling a brand new Fluidampr...
http://forums.corvetteforum.com/c5-p...ing-cover.html
It has a 10% underdrive and it will balance just as good as an ATI.
Some info here: http://www.fluidampr.com/FACTS.htm
Old 11-20-2011, 09:20 AM
SouthernSon
SouthernSon's Avatar
Location: Deal's Gap 2004 NCM Motorsports track supporter
Received 1,103 Likes on 717 Posts
ATI. I previously had an 'off - brand' that separated on me. I had to chase one down at ATI 'headquarters' by talking to a member of the owner family. He is not really good with people or just doesn't like his job. Will never buy another ATI if another company makes one comparable. But as far as the product, it is good.
Old 11-20-2011, 06:37 PM
davidfarmer
davidfarmer's Avatar
ATI developed their damper with GM racing's help, getting the correct rubber to keep the engine happy. I wouldn't consider anything else personally
Old 11-20-2011, 09:56 PM
travisnd
travisnd's Avatar
ATI 10% underdrive w/o any AC provision. Steel hub, aluminum serpentine damper. They make an all aluminum one and one with the AC pulley. ATI is now making a 25% underdrive version, but I've always stuck with the 10%.
Old 11-21-2011, 02:50 PM
John B
Pro Mechanic
John B's Avatar
I have had a few separated powerbonds come in the shop.
Old 11-21-2011, 08:02 PM
VGLNTE1
VGLNTE1's Avatar
How? Mines a solid design, there is no compound between it like the stocker
Old 11-22-2011, 12:02 PM
Gering
Tolero Apto Victum
Gering's Avatar
Also OP: Nice looking C5.
Old 11-24-2011, 07:32 PM
Rob's 73
Rob's 73's Avatar
ATI here. Broke two timing chains with cheaper version.
Old 11-24-2011, 07:48 PM
Gray Ghost GS
"AlohaC5" Senior Member
Gray Ghost GS's Avatar
+1 ATI 10% underdrive
Old 11-24-2011, 08:35 PM
VGLNTE1
VGLNTE1's Avatar
What were the brands?
Old 11-25-2011, 05:34 AM
Rob's 73
Rob's 73's Avatar
ASP. One of the chains was a double. It lasted 15 track days.
To what underdrive pulley you guys run?
Quick Reply: what underdrive pulley you guys run?
