Trans oil cooler - plumbing, filter?
Old 11-21-2011, 02:11 PM
RX-Ben
RX-Ben's Avatar
Default Trans oil cooler - plumbing, filter?
Took a really quick look but don't have time to mock up before I make sure I have everything needed - I see there is a T fitting included - are there 2 scavenge lines or 2 feeds?
Has anyone used an in-line filter on the scavenge side? Seems like a good idea. Looking to use a "coarse" one (filters down to .050") since the 149 micron ones seem like they will clog regularly (pain to replace the screen). Any thoughts?
Thanks.
Old 11-21-2011, 02:35 PM
travisnd
travisnd's Avatar
Never heard of a filter on a trans or diff cooler setup. Which setup did you go with?
Old 11-22-2011, 11:12 AM
96CollectorSport
96CollectorSport's Avatar
Location: If you don't weigh in you don't wrestle Road America
I've used these on several cars in the past and have never found them to get clogged up.
http://www.summitracing.com/parts/EAR-230306ERL/
Let's put it this way if it's clogged, you've got bigger issues.
I put them in line to help try to save the pump if something does go wrong.
It's just a screen, you could probably go to a hardware store and find a more coarse screen if you felt the one that came with it was too restrictive.
Old 11-22-2011, 12:26 PM
travisnd
travisnd's Avatar
Ahhh... the "saving the pump" part makes sense.
Old 11-24-2011, 01:19 AM
CP Thunder
CP Thunder's Avatar
Filter saved our pump. Gasket material used in a rebuild clogged the filter.......was doing a fluid change and used the pump to cycle the old out........barely got a trickle.......pulled the filter and it was PACKED with rubber chunks.
Always use a filter.............
To Trans oil cooler - plumbing, filter?
Quick Reply: Trans oil cooler - plumbing, filter?
