Daytona HPDE checklist update - input
Old 11-21-2011, 05:39 PM
waddisme
Support Corvetteforum!
waddisme's Avatar
Default Daytona HPDE checklist update - input
Doing the Hooked on Driving Daytona HPDE next Fri and Sat. Anything extra to add or do before going? I have new rotors for front with new XP12s, new oil, bought 2 more wheels to mount extra set of R80s on just in case, BFG KDWs street tires in case it rains and of course redoing my oil cooler lines. Here is my current checklist:
• HELMETS and Gloves
• Paperwork (completed)
• Required clothing (long sleeved shirt and cotton long pants)
• Listing of Computer Codes
• Tire pressure gage
• Tire air compressor w/fix-a-flat
• Engine oil (1-2 quarts)
• 1 container of brake fluid
• Brake bleeding equipment (tube/bottle, etc.)
• Duct tape
• Fire extinguisher
• WD-40
• Paper towels / rags / wipes
• Cotton towel for yourself
• Torque wrench w/ socket
• Brake pads repl tools – 16mm wrench, 21mm socket(bracket), 15mm(pads)
• Other tools (sockets, wrenches, pliers, screwdrivers, etc...)
• Contact paper w/scissorsWindshield cleaner
• Spare parts:
o Serpentine belt
o Brake pads
o Rotors (front & rear)
o Caliper bolts and caliper bracket bolts and caliper pins
o Wheel studs and lug nuts
o Clamp kit
o Spare Slicks/Rain tires
o Hoses
o Endlinks
• Jack
• Jack stands
• Impact wrench w/breaker bars
• Gloves – Mechanix
• Funnel for oil
• Grease
• Ice chest (Drinks, energy bars, snacks)
• Sunglasses
• Sun screen
• Camera w/lenses and charger
• Extra tapes.
• Power Converter/Iphone charger/Mount
• Flashlight
• Gas Tank
• Folding chairs
• Tent
• Ground tarp
• Rain tarp
• Extra set of keys
• TrailerAid
Anything else I should add or do? I have done the Charlotte Motor Speedway for the past 4 years so I know to bump the air pressure up 4 lbs per Hoosier. Input greatly appreciated.
Old 11-21-2011, 06:19 PM
gmccreary
gmccreary's Avatar
Assorted zipties. I got a 900 piece set from Northern Tool for $10.
Old 11-21-2011, 06:57 PM
AU N EGL
AU N EGL's Avatar
Video camera and take lots of video
Post when you get back
Have fun
Old 11-21-2011, 07:29 PM
varkwso
varkwso's Avatar
Intestinal fortitude.
Old 11-21-2011, 08:25 PM
waddisme
waddisme's Avatar
I have the 200 asst zipties from HF. 1 8g sd card. If it is anything like Charlotte, then I'll haul *** down the straights, stand on the brakes before hitting the turns.
Old 11-21-2011, 08:56 PM
StKnoWhere
StKnoWhere's Avatar
You will have a blast - enjoy!
Old 11-21-2011, 09:17 PM
Gray Ghost GS
"AlohaC5" Senior Member
Gray Ghost GS's Avatar
Have fun! Daytona is also on my Wish List! Perhaps 2013.....
Old 11-21-2011, 09:55 PM
Greywolfe
Greywolfe's Avatar
Titanium lugnuts !!!
Old 11-21-2011, 10:29 PM
BEZ06
BEZ06's Avatar
Yeah, absolutely necessary!!!
Waddisme, we are gonna have FUN!!! I'll see you there!!!
Did you go for a garage?
I know it's expensive, but it's very nice to pull in out of the sun and sit in the shade next to the car, plug in your computer or charge your video camera, and just relax. If you don't have a garage, feel free to find me to charge cameras, etc.
The main reason I asked is that you mentioned a tent, ground tarp, etc.
There isn't anywhere in the paddock area that I can think where you can stake down a tent - it's all paved. So if your tent isn't free standing, maybe you can use those spare rotors to hold it in place!!
It was 82* today, and forecast to be about 78 to 80 through this weekend for the Turkey Run. The extended forecast only goes up through a couple days before the event, but shows that it should be cooling down to highs around 70 to 72 with good weather - hopefully that will hold through the event!!
C'ya at the track!!!
Bob
3.56-mile, 12-turn speedway road course
Old 11-22-2011, 04:05 PM
sgsvette
sgsvette's Avatar
QUOTE:"Anything else I should add"
I didn't see "PIT TOOTSIE" on the list
Old 11-22-2011, 05:38 PM
BEZ06
BEZ06's Avatar
Hey Henry - isn't that supplied by HOD???
Bob
Old 11-22-2011, 05:57 PM
sgsvette
sgsvette's Avatar
Bob
Problem is..... they sleep all day after dancing all night.
Old 11-22-2011, 07:59 PM
StKnoWhere
StKnoWhere's Avatar
Bob
You guys are dreaming, they usually hang out with the Ferrari's...
Old 11-22-2011, 08:14 PM
BEZ06
BEZ06's Avatar
Hmmmm, maybe if I wear a red jumpsuit with some exotic marque patches......
Naaahhh, fagitaboudit!!!
I think I better just stick with my normal pit crew!!
C'ya at the track!!
Bob
Old 11-22-2011, 10:56 PM
waddisme
waddisme's Avatar
Only good thing about ricers and HPDEs - they usually have some hot chicks with them.
Old 11-23-2011, 12:25 AM
RX-Ben
RX-Ben's Avatar
If you are putting on new rotors, get some heat into them before you get to the track (with the XP12s on the car, and don't use street pads before the event) - either do ~10 hard stops from 80 or so or drive with your foot on the brake and gas. Do a few hard stops on your outlap (offline) or the gas/brake thing to clean off uneven buildup.
Don't forget to drink a lot of water.
Bring: Brake piston compressors, numbers
If it is your first time at the track, watch all the vid you can. After a while, practice brake/gas/shifting/steering. It is lame, but it works. Your brain can't tell the difference and you'll be 80% there by the time you show up (IME), and confident.
Old 11-23-2011, 11:16 AM
waddisme
waddisme's Avatar
I will bed them per Carbotechs before I load on trailer. I was thinking about doing the first couple of sessions on my BFG (Y rated) street tires to make sure my R80 scrubs will make it thru the weekend. Will be watching a lot of videos. I like the idea of mentally driving and shifting along with videos. Thanks.
Old 11-23-2011, 03:08 PM
Seadawg
Seadawg's Avatar
Bob
I hope to see you there Bob, and may even run into you at the Turkey run this week.
I won't be entered for this one, but hopefully next time.
Ron
Old 11-24-2011, 10:19 AM
Don O.
Don O.'s Avatar
Default Daytona
I will be there too. I will have a red LS powered Panoz there. Look for a black hauler behind a black Avalanche. Look me up if anyone needs help with anything. Glad to help!
You will leave the weekend with a big smile on your face!
See you there!
Don
To Daytona HPDE checklist update - input
Quick Reply: Daytona HPDE checklist update - input
