Advice on wheel size
Old 11-22-2011, 10:05 AM
JohnAlley
JohnAlley's Avatar
Default Advice on wheel size
Getting ready to convert car to full time track car and need some advice on wheel size. I have a 2004 Z06 and want to run a squared set-up. What is the recommeded wheel size for best performance 17" or 18" on all four corners ? Will be buying the wheels this winter and want to make sure I get what will work best. Will be running the car in NASA TTA in 2012.
Old 11-22-2011, 10:33 AM
96CollectorSport
96CollectorSport's Avatar
Location: If you don't weigh in you don't wrestle Road America
C5 Z06 wheels 18x10.5" they give you most possibilities anything from a 255 - 315 fit on those wheels.
Old 11-22-2011, 11:34 PM
travisnd
travisnd's Avatar
Most popular option is OEM Z06 rear wheels all around. They're light, strong, cheap and can fit 255s-315s.
Took me forever but I gathered up 8 18x10.5 Alcoas which came on 2001 Z06s only. They're forged vs. the spuncast Speedlines that came on 2002-2004s.
Old 11-23-2011, 06:01 AM
JohnAlley
JohnAlley's Avatar
Default Thanks !!!
THanks for the info, can't wait till spring to get back in the car again.
Old 11-23-2011, 07:36 AM
varkwso
varkwso's Avatar
The GS 17x11 are also great but the OEM ones are getting tough to find. Avoid aftermarket ZO6 or GS wheels they are a LOT heavier then OEM.
Old 11-23-2011, 09:03 AM
JimbeauZ06
JimbeauZ06's Avatar
I think the 18s also give you much better access to scrub Hoosiers if you ever need them.
BTW I have two sets of Speedlines. I know the one set came from my
'01, but not sure what year the others came off of. Is there an easy way to tell the difference?
Old 11-23-2011, 09:38 AM
travisnd
travisnd's Avatar
The spokes on the Alcoas have a sharper edge and the wheels are a slightly darker color. The Speedlines have a roudned edge on the spokes and are slightly lighter. Also, the Speedlines say "Speedline" on the back whereas the Alcoas have "GM" sort of etched on the back.
Speedline wheel markings:
2001 Alcoa Z06
Old 11-23-2011, 09:41 AM
Scooter70
Scooter70's Avatar
Your '01 came with Alcoa wheels.
http://forums.corvetteforum.com/c5-t...06-wheels.html
I have one set of Alcoas and one set of Speedlines.
Old 11-23-2011, 10:01 AM
ErnieN85
ErnieN85's Avatar
they are cast in the back of the spokes (identifers)
To Advice on wheel size
Quick Reply: Advice on wheel size
