C5 Stock Replacement Front Two Piece Rotors?
Old 11-28-2011, 09:53 AM
varkwso
varkwso's Avatar
Default C5 Stock Replacement Front Two Piece Rotors?
Who makes the best ones and why? The ones I am interested in are a replacement for the c5 front stock rotor using C5/6 calipers.
Old 11-28-2011, 11:05 AM
travisnd
travisnd's Avatar
I've had good results with the DBA slotted 2-piece from KNS Brakes
Old 11-28-2011, 11:20 AM
sperkins
sperkins's Avatar
Mark
Old 11-28-2011, 12:04 PM
drivinhard
Support Corvetteforum!
drivinhard's Avatar
DBA and wilwood likely the least expensive. Brian has done well with his DBA
Old 11-28-2011, 12:26 PM
SouthernSon
SouthernSon's Avatar
Location: Deal's Gap 2004 NCM Motorsports track supporter
Received 1,103 Likes on 717 Posts
Have run the AP T1 2pc. from Hardbar this year. So far, so good. Hawk 70's haven't hurt them too bad, yet. Same size as OEM.
Old 11-28-2011, 12:32 PM
Last C5
Last C5's Avatar
I'm using the Stoptech Aero 2 piece rotors because when you figure in the replacement ring costs they end up a little cheaper over time than some of the others. They've been working well.
Old 11-28-2011, 12:33 PM
varkwso
varkwso's Avatar
Looked at his post $369 seems killer and he has them! How much are rings and how are yours wearing?
Old 11-28-2011, 12:34 PM
varkwso
varkwso's Avatar
Originally Posted by sperkins
Mark
I am hoping to get the fencesitters...
varkwso
varkwso's Avatar
What rings do they use?
Old 11-28-2011, 12:35 PM
varkwso
varkwso's Avatar
Big $$ - are they that much better?
Old 11-28-2011, 12:53 PM
travisnd
travisnd's Avatar
I don't know... haven't bought any yet. Bought two sets of rotors in summer 2010 and only switched to the 2nd set because I put Wilwoods up front which had a different firepath.
Here's the original set after a 9 track weekends (was test fitting the Wilwoods). They're my backups now.
Old 11-28-2011, 01:37 PM
SouthernSon
Ooops, sorry buddy. I missed the 'why?' in your OP. The AP have more and closer spacing on crossbridges to keep warping/expansion dips to minimum. I have not experienced any knock back with the wilwood SL6's (no anti-knock back springs). They are a little pricey - $1K for front set only and replacement rotors around $250 each. However, no down time working up a sweat in July while changing cracked rotor.
Old 11-28-2011, 06:18 PM
gkmccready
gkmccready's Avatar
I thought Gary said his 2pc rotors wouldn't work with the stock slide rail calipers due to clearance issues?
Old 11-28-2011, 06:39 PM
SouthernSon
Well, could be. When I spoke with him last year I already had the Wilwoods mounted there. I know they are the same diameter as OEM, more or less.
Old 11-28-2011, 07:12 PM
Last C5
Last C5's Avatar
They use Stoptech rings which go for $150 each.
Old 11-28-2011, 07:15 PM
63Corvette
63Corvette's Avatar
I concur
Old 11-29-2011, 12:07 AM
Gering
Tolero Apto Victum
Gering's Avatar
I have a set of these on my C6 and like them a lot. They are lite and lasted a long time for me. http://shop.performanceafx.com/C5-Corvette_c13.htm
To C5 Stock Replacement Front Two Piece Rotors?
Old 11-29-2011, 09:29 AM
96CollectorSport
96CollectorSport's Avatar
Location: If you don't weigh in you don't wrestle Road America
We've had very good results with StopTech rotors, between $650-$700 for the initial purchase and $140 - $150 for replacement rings.
Heck we got lucky and found a used set of rotors and hats for $300 a few years ago. It's nice to have spares
Old 11-29-2011, 10:18 AM
varkwso
varkwso's Avatar
Looks like they run from ~$320 to ~$1000. I have seen the Stoptechs, AFX, DBA, Hardbar and Wilwood all on track and in the paddock. Cracking seems to be way less common (as it should be!).
Old 11-29-2011, 10:46 AM
96CollectorSport
You are definatly going to want to find out what the replacement rotor costs are going to be up front. Also see how difficult/easy it is for you to get replacement rotors - if there is a vendor in your area or if you have to order them yourself. Some of the stuff coming from Cali can take a week for you to get.
Quick Reply: C5 Stock Replacement Front Two Piece Rotors?
