ARP Flywheel Bolts - Reuse Once or Not?
Old 12-03-2011, 10:25 AM
mcar00
mcar00's Avatar
Default ARP Flywheel Bolts - Reuse Once or Not?
Has anyone had any experience reusing ARP flywheel bolts? This is a 9 bolt application and I'm trying to determine whether it's safe to reuse them once. I know, it's safer just to replace them but I'd hate to pitch some perfectly good bolts if that's the case especially if new ones are around $50. Thanks
Old 12-03-2011, 01:44 PM
0Bobby @ LG Motorsports
Former Vendor
Bobby @ LG Motorsports's Avatar
We re-use them until we cant get them off, or torque them down because they are worn down and the socket wont grab
never had a failure, 6 bolt or 9 bolt, just be sure to torque to 60ftlbs, and use red loctite.
Old 12-03-2011, 02:09 PM
Aardwolf
Aardwolf's Avatar
The flywheel will wear out first!
Old 12-03-2011, 02:31 PM
thehammer69
thehammer69's Avatar
Reuse them
Old 12-03-2011, 04:31 PM
mcar00
mcar00's Avatar
Thanks guys. Will reuse.
To ARP Flywheel Bolts - Reuse Once or Not?
Quick Reply: ARP Flywheel Bolts - Reuse Once or Not?
