opinions on best aluminum flywheel - spec, fidanza or RAM?
Old 12-09-2011, 10:46 AM
2MCHPWR
2MCHPWR's Avatar
Default opinions on best aluminum flywheel - spec, fidanza or RAM?
fidanza is about $435 shipped.
RAM $335 plus shipping.
SPEC $360 shipped
will be used on stock c5 z06 with ls7 clutch.
any quality differences?
Old 12-09-2011, 11:50 AM
sebdavid
sebdavid's Avatar
interested in answers as well.
Old 12-09-2011, 04:39 PM
Black89Z51
Suckin' gas, haulin' ass.
Support Corvetteforum!
Black89Z51's Avatar
Albeit not on an LS motor, I've got a SPEC on my 89 and have had zero issues with it. Keep in mind that if you decide to go with the SPEC clutch, and order a clutch from SPEC with the flywheel, they will come as a balanced assembly. They will be bolted together when it arrives, so make sure you mark it so that they go back together the same way when you are installing it.
Old 12-09-2011, 04:41 PM
Canam
Canam's Avatar
AASCO. I changed from a fidanza to one after it shattered. Best move I ever made. Don't know about the Ram but I have a Ram clutch and its really good.
Fidanza is out of business now I hear.
Old 12-09-2011, 09:53 PM
fatbillybob
fatbillybob's Avatar
Exploding clutches and flywheels can kill you. I'd make sure the flywheel aluminum or steel was SFI rated. After that it is tomato or tamato.
Old 12-10-2011, 04:52 AM
Brent Dalton
Brent Dalton's Avatar
What car is this going in? Going for a AutoX/track day set up again? Is the car street driven? Spec has less than stellar customer support in my experience with them.
Old 12-10-2011, 08:21 AM
2MCHPWR
2MCHPWR's Avatar
yeah c5 z06 for HPDE/AX and street.
I have to do more research to their weights. I think fidanza weighs the least.
thanks guys!
Old 12-10-2011, 01:13 PM
Canam
Canam's Avatar
thanks guys!
thats the problem. Compare a fidanza to an AASCO. The centre meat is half as thick. Go lighter and maybe blowup? Thats not good. I proved that. Be careful.
Old 12-10-2011, 08:13 PM
travisnd
travisnd's Avatar
I had a Luk Stage II clutch with a Fidanza aluminum flywheel in m old Z06. Never had any issues with it.
Old 12-13-2011, 11:27 AM
Deus_Ex
1st Gear
Deus_Ex's Avatar
Default Lightweight flywheels...
Not sure about Canam's comment, but no known record of a Fidanza piece shattering. All their stuff is 6061 T6 billet; they've been around for years and started as a race shop building cars. I do know they are still in business and going strong. Check on the web.
Old 12-13-2011, 12:41 PM
C5ZEE06
C5ZEE06's Avatar
Ive heard that the Spec piece is actually made by Fidanza...not sure if its to the same spec tho (no pun intended) so they may not be directly comparable.
+1 on Spec customer service....if you have a problem..don't expect them to step up ..cause they won't.
never had a problem with Fidanza flywheels.
To opinions on best aluminum flywheel - spec, fidanza or RAM?
Quick Reply: opinions on best aluminum flywheel - spec, fidanza or RAM?
