Would thes rotors be better than stock for autocrossing?
Old 12-09-2011, 11:22 AM
Red5
Red5's Avatar
Default Would thes rotors be better than stock for autocrossing?
http://forums.corvetteforum.com/c5-p...9-shipped.html
Wanted your opinions on these. I'm looking for more stopping ability.
Old 12-09-2011, 11:46 AM
SteveC68
SteveC68's Avatar
For auto-x stock rotors are fine. Try some different pads.
Old 12-09-2011, 11:48 AM
johninar
johninar's Avatar
I'd be focusing on pads
Old 12-09-2011, 11:49 AM
sebdavid
sebdavid's Avatar
Changing rotors isn't going to make a difference. Changing pads, perhaps. Are you able to get into ABS for the duration of the run? I would think so, and if so, then you don't need more braking power, you need more grip. For an autocross, I would think even the stock C5 setup with good pads would be good enough to get into ABS for the whole run without fade.
To Would thes rotors be better than stock for autocrossing?
Quick Reply: Would thes rotors be better than stock for autocrossing?
