C5 Z06 rear tub
C5 Z06 rear tub
Been working on taking lots of parts off my car and it looks like the rear tub will need to be replaced as it got smashed up pretty good in the wreck. Does anyone sell the rear tubs?
I've never taken that part off a vette before so I'm still trying to learn more about it.
I got my C6 rear tub off of a Corvette recycler on eBay.....same guy I got my frame from....http://showmewrecks.com. It is glued on, so it is fun to get off...my "new" one is bolted on for ease of removal.
Supporting Vendor
St. Jude Donor '11
Also check with Marc at www.vettenuts.net south of Nashville.
Give me a call when you can and we can work out a time to come pick it up.
615-896-6100
Jason give me a call to so we can get some logos out to you.
Thanks Marc... I just read your email too. I wasn't sure if you had those in stock as well. I'll give you a call tomorrow
Marc,
Can you tell us some tips of how to break the epoxy bond without destroying the tub? Is there a special powered putty knife kind of tool that is sharp that can be pushed through the epoxy to section it?
Can't you just "glass" yours up? Must be really really bad....?
hey, you can get a Carbon tub from ACP.......
Supporting Vendor
St. Jude Donor '11
Hope this helps.
x2. Vettenuts is about 30 minutes South of Jerry's shop and are def. good people. I've had a few things on the C5Z and LS1 RX7 that I've had to replace while at the shop on a Saturday. Very nice being able to give VetteNuts a call and jump in the truck and have what I need in an hour or two! I know Jerry, Richard, and all the other guys at the shop and the local area are glad to have Vettenuts in close proximity!
The powers that be, are looking at the "floorpan rules" regarding Corvettes. (It started with Mustangs) The trunk area is "floorpan", including fenderwells. I do not know how "perfect" they require. You might want to ask.
Supporting Vendor
St. Jude Donor '11
I have repaired light damage to some coupes and the first one i did the RR quarter panel gap at the door never was right. You have to get the repair area perfect otherwise it will show up on all the body panels. After several cars i started replacing the tub to insure proper alignment.
