FS - (4) Hoosier R6 285/30-18 3 Heat Cycles $350
Old 12-28-2011, 02:37 AM
Sidney004
Sidney004's Avatar
Default FS - (4) Hoosier R6 285/30-18 3 Heat Cycles $SOLD
Very Fresh, Size wise, these are quite similar to the 295/30-18, the O.D. is 24.9" , the O.D. on the 295/30 is 25.3" so the car will drop .2" . I measured the thread depth and none was less than 3/32nds. I can ship 4 tires via Greyhound freight for $75, you would need to pick them up at the bus station however.
(925)354-1571
Hoosier Catalog: http://www.hoosiertire.com/pdfs/pricescr.pdf
Quick Reply: FS - (4) Hoosier R6 285/30-18 3 Heat Cycles $350
