ANyone have experience with Brembo race calipers?
Looking at some Brembo calipers, anyone had experience with them?
For Corvette use you would need trailing calipers for the front
and leading calipers for the rear.
If all of the pistons were the same size then
you could mount them in any postion as long as the bleeders and fluid supply pipes are in the correct postions.
If you had calipers that had staggered piston sizes
then you would have right side calipers and left side calipers
And as long as the bleeders and fluid lines can be repostioned
then you can configure them for leading or trailing.
From what I can tell Brembo calipers can be configured
to be either trailing or leading , only needing to make sure
they are on the correct side of the vehicle.
