ACP 2" front splitter with no undertray?
I have a ACP 2" front splitter. I want to run no undertray and close up the vents in the center of the splitter. So the car would still be a bottom feeder from the air that is getting under the splitter. It would be about 3" off the ground at the most. I'm not worried about cooling for now. Would this setup still create downforce? I would think that I'm cutting off half the air that would normally get under the car, by the lower splitter height.
thanks,
Steve A.
thanks,
Steve A.
Steve
I tried this and it did not work. Cooling was poor. and their was quite a bit of lift.
I made an undertray out of lexon, bolted it to the frame and splitter. Cut the rubber air dam in half to direct air up into the radiator.
Tapped off the edges between the undertray and splitter to force air up into the radiator.
Opened the radiator hole from 3" to 5" high to get enough air into the radiator.
My understanding is the spittler is to force air over the splitter to keep air from going under . So to have a bottom breather AND splitter may be defeating each other.
Front 3" opening
Opened to 5"
Front 3" opening
Opened to 5"
I found the splitter not effective as it was so I raised it to 3&1/2" high with plywood and spray can paint.
After an off road excursion I modified it to 3" and removed the center opening post and removed the curved up portion of the center duct because the class that I run in doesn't allow the spoiler to direct air into radiator only just let it pass through. You could just stick with the stock center the way it came just raise it to 3" and bend the center air damn to touch the opening and bolt it to the splitter for pretty good air flow to radiator.
Finished splitter without spray can paint and mounting.
I run a 900# frt spring and better shocks so I only need 2&1/2" clearance under the splitter and it will touch once and a while. I would recommend you run 3&1/2 clearance if running close to stk set up.
Thanks guys for the comments. I'm still not getting a grasp on this. Is our goal to get as much air over the top of the car as possible? If so, when I add this splitter and block off the center openings, I essentially still have a bottom feeder car. But with a lot less air going underneath. The splitter is much lower to the ground then the stock front end. If my car can keep cool with this smaller gap between the splitter and the ground then I would think I would have created more downforce. Yes or No? The only reason I think I might get away without the center opening for cooling, is that I only run autocross. I do have a ACP vented hood too. So it's still a bottom feeder, but with a lot less air going under the car. Thoughts?
thanks,
thanks,
bottom feeder will not generate downforce.....your airdam is still creating pressure under the nose (necessary to feed the radiator), and that creates lift. You want all of the air going OVER the splitter, not under it stagnating against an airdam
thanks,
thanks,
FWIW.
thanks,
thanks,
