Performance Friction calipers ZR33 fs
Old 01-02-2012, 02:30 PM
sspeed30043
sspeed30043's Avatar
Default Performance Friction calipers ZR33 fs
If anybody is interested, I've got a pair of Performance
Friction ZR33 calipers for sale on the forum...
http://forums.corvetteforum.com/1579...-post2149.html
Old 01-02-2012, 08:03 PM
trackboss
trackboss's Avatar
How much time is on the calipers?
What is the part#?
Do you happen to have a photo of the bottom?
thanks,
-V
Old 01-02-2012, 08:30 PM
sspeed30043
Don't know how much time on them but I was told that they
came of Jack Roush Jr's car., I bought them from Roush/Yates
P/N 33.355.365.410.13 and 33.355.365.410.14
mountings, 210 MM center to center
Blueprint http://www.peansweden.se/PFC%20ZR33%20Specs.pdf
I am very open to resonable offers :-)
Old 01-02-2012, 10:02 PM
dvandentop
dvandentop's Avatar
i think hardbar sells a bracket to mount these to our cars
Old 01-02-2012, 10:06 PM
sspeed30043
Yep, just checked , still listed on the website.
Old 01-02-2012, 10:46 PM
trackboss
trackboss's Avatar
I'm actually looking around for a caliper for some custom spindles I will be working on. Not for corvette. There is also a set of brembos I am looking at which I am comfortable with the history. These however, I still need to know more about how used they are before making a purchase.
Old 01-03-2012, 11:12 AM
0Louis @ LG Motorsports
Former Vendor
Louis @ LG Motorsports's Avatar
Worst case, it needs seals. The pistons had issues with the coating flaking off, which PFC will fix. Its an issue, and they are aware of it. It was fixed on anything built after 09, if i recall, and it only happens after 20+ hours of use on the pistons.
Its a bad *** caliper, great piston setup with well engineered heat barriers. The material on the heat shield in the piston is rocket nozzle material.
Old 01-03-2012, 11:36 AM
63Corvette
63Corvette's Avatar
Thanks Louis. You are a good source of great information
Old 01-03-2012, 12:18 PM
sebdavid
sebdavid's Avatar
It may be a stupid question, but those (using Hardbar adapters) won't fit a 17" OEM C5Z wheel, will they?
Old 01-03-2012, 09:53 PM
sspeed30043
Dont have a definite answer for you but I dont think they fit anything smaller then a 18" and with a spacer for OEM wheels, I have a set of CCW's I was going to use with them.
Old 01-03-2012, 09:56 PM
sspeed30043
I saw them on your GA car, and was building the car close to GrandAM Specs so when I found htem I snatched them up. To be honest if I could find the matching rears I would probably keep them, but $$ is tight and they arent cheap...
Old 01-04-2012, 04:39 AM
trackboss
trackboss's Avatar
Thanks for the info Louis.
On that note I will consider these. Still need to hear back about the brembos I am also considering.
sspeed30043 I will let you know as soon as I find out.
Old 01-05-2012, 11:48 PM
sspeed30043
Pending sale
Old 01-17-2012, 06:02 PM
Paul Schmidt
Paul Schmidt's Avatar
Originally Posted by sspeed30043
Pending sale
Thank you Tim, they came today.
These will compliment.....
My race car
Thank you again
Old 01-17-2012, 09:42 PM
sspeed30043
Your welcome.....
To Performance Friction calipers ZR33 fs
Quick Reply: Performance Friction calipers ZR33 fs
