Tie Rod Ends? control arm bushings?
Old 01-02-2012, 06:27 PM
JDIllon
JDIllon's Avatar
Default Tie Rod Ends? control arm bushings?
Does anyone make after market Tie Rod ends for the front and rear tie rods on the C6-Z06. Need to replace all of the rod ends they are cracked and leaking grease. The GM parts are very costly. Thanks. JD
Also thinking of replacing control arm bushings? any thoughts?? JD
Old 01-02-2012, 06:54 PM
davidfarmer
Support Corvetteforum!
davidfarmer's Avatar
I'd probably go with one of the bump-steer kits, as they are less expensive and don't have boots. Also, adjustable if you decide to get experimental.
I'm not sure how livable the current crop of poly bushings are, but it's certainly a nice performance boost. Pfadt would be the obvious choice, but I haven't tried them myself.
Old 01-02-2012, 06:57 PM
Short-Throw
Short-Throw's Avatar
JD, psssst, go spherical bearings.
Old 01-02-2012, 07:51 PM
SLandstra_Z06
SLandstra_Z06's Avatar
I have them and am very happy with my Pfadt sphericals.
Old 01-14-2012, 11:25 AM
C6RAPTOR
C6RAPTOR's Avatar
JD
You got me thinking about the Pfadr sphericals.
To Tie Rod Ends? control arm bushings?
Quick Reply: Tie Rod Ends? control arm bushings?
