Weight difference between different brake setups
A while back someone was going to look at the weight difference between our stock C5 calipers/rotors vs going to the C6Z06 or GS brakes. Does anyone know the difference in the various offerings we can put on our cars i.e. C6Z, Baer, Wilwood, Brembo? I am thinking of changing the rear rotors to a +1 setup when I change my brake lines to Stainless. My concern is finding solid rotors for the track, as all the +1 setups seem to be drilled and slotted.
Avoid +1.
Stick with the stock brake setup. Use "real" pads and fluid.
Either stock up on cheap blanks or stock up to a lesser degree on 2 piece front discs.
Solid surface rotors
Race brake pads and better brake fluid.
2-piece rotors are the best idea.
if you do go with a BBK set up that is a major upgrade as you also need wheels to go over the BBKs
I have the solid rotors, race pads, and I run high temp brake fluid. Was just looking for a way to fill in the back wheel some and thought a slightly larger rotor would look good and provide more of a heat sink. My only concern was that you could not get them in a solid configuration, everything seems to be drilled or slotted or both.
Look good?
No Offense, but when you are driving, no one will know.
Slotted rotors are fine, they will scrap the brake pads down quicker
I have been using stock set up, with blank rotors for many years.
Yes I toss the rotors frequently and the calipers every other year or as needed.
with Wilwood H or PFC-01 brake pads, Going into VIR T1 from 130mph, and stopping, will the ABS is a pounding and the car feels like it is doing a motorcycle stoppie and the rear end dances a bit. It does whoa down from the 4 marker very nicely
Look good?
I just put new wheels and tires on in stock sizes, as I don't want to pay the upcharge for a BBK and new wheels. I like the current look and have dropped the +1 idea. Thanks to everyone for the input.
I run DBAs and Wilwood SL6Rs up front... the ones I use a slotted. Not sure of the weight, but they're lighter than the stock stuff. Didn't do the upgrades for weight though... the 2-piece rotors last way longer than the stock one-piece units and the SL6Rs use a 20mm pad which is much thicker than the OEM one and cheaper too.
As far as larger rotors go, Im not 100% sure but I think you can run c6 z51 caliper brackets on the c5.
