LS6 valve spring replacement type?
Old 01-13-2012, 03:23 PM
johninar
johninar's Avatar
Default LS6 valve spring replacement type?
I have a stock LS6 and do 15-20 HPDE days a year. I do not have any plans in the near future of performance upgrades, but will eventually give in and put a cam in it. Since I fall into the period of time that there appears to have been a lot of spring failures, I want to replace them before something happens.
Do I just put OEM springs in it or go with 1218s or some such?
I've read a lot of threads and I just don't know if there is any benfit for me to use an aftermarket spring.
So those of you who track your cars a lot, opinions?
thanks,
John
Old 01-13-2012, 03:36 PM
travisnd
travisnd's Avatar
When prepping my 2001 with 119k miles (122k + now) I swapped in a set of fresh OEM 2002-2004 springs aka "yellows". They're downright cheap from Scoggins-Dicky and properly designed for the stock cam. No need for more spring pressure with a stock setup.
In my old Z06 with a LGM G5-X2 cam I had comp 921s FWIW... good spring for that cam.
Old 01-13-2012, 04:49 PM
RX-Ben
RX-Ben's Avatar
New yellows are fine, 1218s (which have a modest seat pressure) are good as well.
1218s were fine for me this year on heavy LS1 valves and regularly spinning up to 7k.
Old 01-13-2012, 05:09 PM
CHJ In Virginia
CHJ In Virginia's Avatar
After 48K miles total and approximately 20K track miles, I swapped out my springs last year. I also went with the stock yellows. I agree with Travis - they are designed for the engine and there is no sense in going with more pressure or a different design.
Old 01-13-2012, 05:11 PM
RX-Ben
RX-Ben's Avatar
...unless you are using the engine in a manner that was not intended
Old 01-13-2012, 05:46 PM
AU N EGL
AU N EGL's Avatar
Would we do that ? ? ? ?
Old 01-13-2012, 06:41 PM
johninar
johninar's Avatar
Never..
Thanks for the replies.
Now, who has the best price for the Crane tool (on comparable nock-off)?
Old 01-14-2012, 08:24 AM
Vettechris996
Vettechris996's Avatar
I went with stock yellows last spring as well, my 02 had 22k on it at the time.
FYI, the Comp Cams tool fits Gen III/IV LS engines not just gen III. Not a bad investment and it works great.
Old 01-14-2012, 08:56 AM
PA Z06
PA Z06's Avatar
[QUOTE=CHJ In Virginia;1579728089]After 48K miles total and approximately 20K track miles, I swapped out my springs last year. I also went with the stock yellows.
I did the same, its just cheap insurance
Old 01-14-2012, 10:43 AM
UstaB-GS549
UstaB-GS549's Avatar
Originally Posted by johninar
Never..
Now, who has the best price for the Crane tool (on comparable knock-off)?
I used Crane tool to install stock yellow springs in my LS6 a few years ago. I bought it from Vinci Hi-performance in Orlando,FL. Looks like they have their own version for $99. I also bought a spark plug hole air hose from them. Set of springs was around $60 from Gen Culley.
Old 01-14-2012, 11:46 PM
davidfarmer
Support Corvetteforum!
davidfarmer's Avatar
back before the fancy stuff was allowed, we ran the Yellow springs at 7500rpm in World Challenge engines with a largish GM racing cam. Never had a problem with them, and see no reason to change .
Old 01-15-2012, 12:12 PM
ZedO6
ZedO6's Avatar
I just did the valve spring swap and BTW, the new GMPP springs are blue, my old springs were yellow. Car is a 02 C5Z that had 15K. I plan to track the car and leave the LS6 cam in it. I'd rather change these out once a season than screw around with excessive seat pressure and other issues consistent with the wrong springs.
I got all the parts, springs, seals and the Proform tool from Pace for less than $180 delivered. No brainer as far as I can see...did the whole swap in a little over 2 hours.
Old 01-15-2012, 05:31 PM
travisnd
travisnd's Avatar
Odd... it used to be that the 2001 Z06 springs were blue and then the '02+ were yellow. The yellows supposedly have a little more pressure to deal with the higher lift on the '02-'04 cam.
Old 01-17-2012, 06:08 PM
Bad Karma
Bad Karma's Avatar
Might be semantics, but are those blue? They look more green in the picture. Maybe just oil stained.
I am planning on swapping mine out this winter because I too fall into the danger years. I was going to go with GMPP.
Old 01-17-2012, 10:36 PM
travisnd
travisnd's Avatar
Yes... they're blue. They had 119,xxx miles on them.
Old 01-17-2012, 10:46 PM
ZedO6
ZedO6's Avatar
How much of that 117, xxx was on the track? Maybe you had a "good set"
Old 01-17-2012, 10:51 PM
RX-Ben
RX-Ben's Avatar
Hard to argue with this - the only caveat I would add (and why I swapped when using 317 heads) is that if you are using the heavy LS1/LS2 valves then this cannot be directly applied (~20% heavier valves).
Springs like the 1218s and 918s are ovate wire, beehive springs which have some benefits:
http://www.ls1tech.com/forums/advanc...-lift-etc.html
Seat pressure:
http://www.cranecams.com/faqview.php?s_id=33
To LS6 valve spring replacement type?
Old 01-17-2012, 10:53 PM
travisnd
travisnd's Avatar
None... car was a pretty street car until I bought it in 1.5 years ago to make into a dedicated race car. Sapping the springs out was part of my prep in addition to a fresh LS4 high volume oil pump, a LS2 timing chain and lower mileage rockers.
Seat pressure:
I guess my 2001 Z06 falls into the heavy valve category? It was only the 2002-2004 that got the lighter sodium filled intake valves I think???
Old 01-17-2012, 10:56 PM
RX-Ben
RX-Ben's Avatar
Right.
I bought a set of '01s and promptly sold them upon discovering this myself.
Same w/LS2s.
I want to get my $$ worth out of my Katech rod bolts.
Old 01-17-2012, 11:00 PM
travisnd
travisnd's Avatar
Right.
Same w/LS2s.
Did you buy heads off a 2002-2004? Did you get the matching cam? Reason I ask is because the 2001 vs. the '02-'04 cams have a different base circle (I believe the '02-'04 is smaller) Since GM uses the same 7.38" pushrods and rocker arms they correct the geometry/preload through having longer valve stems in the '02-'04 heads.
Quick Reply: LS6 valve spring replacement type?
