FS: C5 harness bar and harnesses
Old 01-21-2012, 09:04 PM
redrckt97
redrckt97's Avatar
Default FS: C5 harness bar and harnesses
for sale is my Arizona Speed & Marine C5 harness bar and (2) sets of G Force 6 point harnesses. The bar is used and has a few scratches in the black paint but mounts/fits perfect. The harnesses are Latch & Hook 3" lap and shoulder with 2" subs. Belts were made in sept 2010 and have only 3-4 uses..never in an accident & look brand new. They have the clip style ends on them but the bolt style brackets are included. (reason for sale is I moved on to C6). Asking price is $290 for the bar and $55 per set for the harnesses. Pics below - thanks for looking. Will ship within the USA.
SOLD
Old 01-23-2012, 09:12 AM
redrckt97
redrckt97's Avatar
ttt
Old 01-23-2012, 09:49 AM
Hat_Trick_Hokie
Hat_Trick_Hokie's Avatar
Does the harness bar require modification to the stock trim pieces? Do you have any installed pictures?
Old 01-23-2012, 10:07 AM
redrckt97
redrckt97's Avatar
I'll check for installed pics on my home computer (at work now)-
the bar requires No modification of the trim (like C6's do) -- you just unbolt the shoulder belt mounts, and set the bar end plates in place, then re-insert and tighten the bolts (one per side) ..the center part of the bar straddles the bulkhead behind the sets, preventing any fore-aft motion of the bar - which menas no -anti-rotation straps are needed like on the Brey-Krause bars.
Old 01-24-2012, 12:33 PM
boomkin
boomkin's Avatar
PM Sent
Old 01-24-2012, 06:27 PM
1stGlance
CF Senior Moments Member
Support Corvetteforum!
1stGlance's Avatar
Default Fit in Convertible ?
Or would I have to cut the center to make it fit ?
Interested!
Old 01-25-2012, 09:29 AM
redrckt97
redrckt97's Avatar
Interested!
haven't seen one in a vert - some other guys may chime in-- seems
like the 'waterfall" may be in the way.
Old 01-25-2012, 01:49 PM
redrckt97
redrckt97's Avatar
ItemS are now sold
To FS: C5 harness bar and harnesses
Quick Reply: FS: C5 harness bar and harnesses
